Home > Puma (Tdci) > MAF Sensor out of range - P1103 |
mrwoo Member Since: 03 Jan 2008 Location: Cheshire Posts: 286 |
I have this code probably because my EGR is (partially) blanked. Have you fitted an aftermarket airfilter? This will increase the airflow. |
24th Feb 2010 4:46pm |
WinBoot Member Since: 09 Jan 2010 Location: Ieper Posts: 28 |
Yes ive fitted an aftermarket but i dont want to remove it, any solutions?
24th Feb 2010 5:23pm |
Dont worry about it, P1103 means it out of range but not in fault. The ECU will class this as extra load and supply more fuel accordingly. |
24th Feb 2010 7:33pm |
But it wont go away will it? |
24th Feb 2010 11:01pm |
Anyone has a solution to make it disappear without changing the filter? |
26th Feb 2010 11:28am |
