Home > Puma (Tdci) > Gear lever rattle |
ralton Member Since: 04 Feb 2010 Location: Durban Posts: 153 |
Hi there
Do any of you have a bit of a gear lever rattle, especially when the engine is at lower revs (1700-2100) in 6th under a bit of strain (mostly going up inclines, etc). Is this normal? What's the cause? Cheers |
23rd Feb 2010 11:33am |
DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2046 |
Yes mine does this as well.
23rd Feb 2010 11:44am |
Higgers Member Since: 08 Apr 2009 Location: Cheshire Posts: 668 |
Guys,
Had the same problem: http://www.defender2.net/forum/topic1433.html New gear stick assembly solved the problem - warranty work. Cheers Ian |
23rd Feb 2010 12:07pm |
Thanks for this - is that a big job? Do you believe there would be long term expensive damage if not corrected? Cheers |
23rd Feb 2010 1:13pm |
Not a big job, just get it done under warranty
23rd Feb 2010 1:19pm |
I'm wondering if they don't all do it (at least a little)?
I remember reading in the Owners Manual how important it is not to "hold" the gear lever - maybe there's supposed to be some movement? |
24th Feb 2010 5:11am |
CapeLandy Member Since: 21 Jul 2008 Location: Cape Town Posts: 558 |
also had the same, I did complain about it but they never said on the repair sheet that they attended to it.
That being said, it has not yet re-occurred although it only happened on a very long haul once everything is nice and hot. I will be testing mine again in a few weeks on a trip into the mountains again |
24th Feb 2010 5:21am |
well, i took it in to the dealer and they replaced the gear lever assembly, and now it is so much better!
25th Mar 2010 12:44pm |
Malcolm Member Since: 17 Sep 2008 Location: Durban Posts: 10 |
I get a humming noise when going up hills in 6th. It seems to" drone" but I can't seem to locate where the noise is comming from. Ralton, do you get yours serviced at LR Durban or Umhlanga as I reported it and nothing was done.
Thanks, Malcolm Ex 2008 Puma 90 2012 Puma 110 |
27th Mar 2010 9:14am |
I use Umhlanga.... Cheers |
28th Mar 2010 4:29pm |
lrdxb110 Member Since: 09 Jul 2009 Location: Dubai Posts: 224 |
Having the same problem especially when speeding up it rattles, bought the issue up with my dealer while my car is in the LR garage, going to repair the rattle and its covered under warranty. '08 LR Defender 110
'08 Mini Cooper S - Sidewalk '86 MB 500 SL '79 MB 450SEL 6.9 |
29th Mar 2010 6:09pm |
