Home > Puma (Tdci) > Gear lever rattle
ralton
South Africa 2007 Defender 90 Puma 2.4 SW Zermatt Silver
Gear lever rattle
Hi there
Do any of you have a bit of a gear lever rattle, especially when the engine is at lower revs (1700-2100) in 6th under a bit of strain (mostly going up inclines, etc).
Is this normal? What's the cause?
Post #24929 23rd Feb 2010 11:33am
DAZ110
Yes mine does this as well.
Post #24931 23rd Feb 2010 11:44am
Higgers
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Firenze Red
Guys,
Had the same problem:
http://www.defender2.net/forum/topic1433.html
New gear stick assembly solved the problem - warranty work.
Ian
Post #24933 23rd Feb 2010 12:07pm
ralton
Thanks for this - is that a big job? Do you believe there would be long term expensive damage if not corrected?
Post #24939 23rd Feb 2010 1:13pm
Higgers
Not a big job, just get it done under warranty
Post #24940 23rd Feb 2010 1:19pm
mse
I had it done - its not the selector as such its the guide.
But when they broke the selector they fitted a new one. Problem is the new one is doing it...but a lot less.
It was in today and they cant get it to do it Evil or Very Mad Evil or Very Mad but i can...just when they arent there. Mike
Post #24966 23rd Feb 2010 7:34pm
ralton
I'm wondering if they don't all do it (at least a little)?
I remember reading in the Owners Manual how important it is not to "hold" the gear lever - maybe there's supposed to be some movement?
Post #24984 24th Feb 2010 5:11am
CapeLandy
South Africa
me too
also had the same, I did complain about it but they never said on the repair sheet that they attended to it.
That being said, it has not yet re-occurred although it only happened on a very long haul once everything is nice and hot.
I will be testing mine again in a few weeks on a trip into the mountains again Very Happy
Post #24986 24th Feb 2010 5:21am
ralton
well, i took it in to the dealer and they replaced the gear lever assembly, and now it is so much better!
Post #27993 25th Mar 2010 12:44pm
Malcolm
South Africa 2012 Defender 110 Puma 2.2 CSW Fuji White
I get a humming noise when going up hills in 6th. It seems to" drone" but I can't seem to locate where the noise is comming from. Ralton, do you get yours serviced at LR Durban or Umhlanga as I reported it and nothing was done.
Thanks,
Malcolm Ex 2008 Puma 90
2012 Puma 110
Post #28214 27th Mar 2010 9:14am
ralton
I use Umhlanga....
Post #28288 28th Mar 2010 4:29pm
lrdxb110
United Arab Emirates 2008 Defender 110 Puma 2.4 CSW Stornoway Grey
Having the same problem especially when speeding up it rattles, bought the issue up with my dealer while my car is in the LR garage, going to repair the rattle and its covered under warranty. Mr. Green '08 LR Defender 110
'08 Mini Cooper S - Sidewalk
'86 MB 500 SL
'79 MB 450SEL 6.9
Post #28382 29th Mar 2010 6:09pm
