Home > Maintenance & Modifications > Added second interior light to my DCPU
Page 2 of 2 <12
Check the earths on it. Thumbs Up
Post #338785 17th Jun 2014 6:10pm
Bristol 90XS
Thanks Steve, will check, but the only earth I have gone into is the rear light and that is a piggy back crimp connector - haven't connected the wire to anything else yet! O you think if this is broken circuit then this could cause the issue?
Also have I done the wiring correctly? Is it ok to take the feeds fm all three wires? Seems to be the easiest way to do it but am questioning myself now!!
Thanks
James
Post #338822 17th Jun 2014 7:34pm
rustyboxx
United Kingdom 2015 Defender 90 Puma 2.2 CSW Montalcino Red
Here you go, all three connections go to the second row light Smile just make sure you connect them to the proper terminals.
 2015 90 XS CSW TDCi - Beautiful
2007 110 XS DCPU - An itch that needed scratching
2005 90 Td5 XS CSW - Utterly brilliant
2001 Discovery 2 ES Auto - A phase I went through
1996 90 Tdi CSW - Uber reliable
1989 90 2.5 Petrol Hardtop - My first proper Landy
1985 Range Rover Vogue V8 -Troublesome
Post #338830 17th Jun 2014 8:04pm
Bristol 90XS
Thanks will check again, that is how I have it wired aside from I am using crimps...
Hopefully I can get to the wiring without taking the head lining down again Sad
Now to wire up the vanity mirror... Any know if it is the purple or the white/purple that has permanent live? Currently they both seem to be live?
Thanks
James
Post #338836 17th Jun 2014 8:31pm
rustyboxx
I'd suggest flicking the switch on the light to turn it on (with the doors shut) and see which contacts are supplying the feed to the switch in that position. Thumbs Up 2015 90 XS CSW TDCi - Beautiful
Post #338838 17th Jun 2014 8:37pm
Page 2 of 2 <12
