![]() | Home > Maintenance & Modifications > Added second interior light to my DCPU |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20638 ![]() ![]() |
Check the earths on it.
rustyboxx Member Since: 08 Oct 2012 Location: Poole Posts: 548 ![]() ![]() ![]() |
Here you go, all three connections go to the second row light
![]() ![]() Click image to enlarge 2015 90 XS CSW TDCi - Beautiful 2007 110 XS DCPU - An itch that needed scratching 2005 90 Td5 XS CSW - Utterly brilliant 2001 Discovery 2 ES Auto - A phase I went through 1996 90 Tdi CSW - Uber reliable 1989 90 2.5 Petrol Hardtop - My first proper Landy 1985 Range Rover Vogue V8 -Troublesome |
Bristol 90XS Member Since: 31 Oct 2010 Location: North of Bath Posts: 223 ![]() ![]() |
Thanks will check again, that is how I have it wired aside from I am using crimps...
Hopefully I can get to the wiring without taking the head lining down again ![]() Now to wire up the vanity mirror... Any know if it is the purple or the white/purple that has permanent live? Currently they both seem to be live? Thanks James |
I'd suggest flicking the switch on the light to turn it on (with the doors shut) and see which contacts are supplying the feed to the switch in that position.
![]() 2007 110 XS DCPU - An itch that needed scratching 2005 90 Td5 XS CSW - Utterly brilliant 2001 Discovery 2 ES Auto - A phase I went through 1996 90 Tdi CSW - Uber reliable 1989 90 2.5 Petrol Hardtop - My first proper Landy 1985 Range Rover Vogue V8 -Troublesome |
