Home > Maintenance & Modifications > Added second interior light to my DCPU |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20376 |
Check the earths on it.
17th Jun 2014 6:10pm |
rustyboxx Member Since: 08 Oct 2012 Location: Poole Posts: 548 |
Here you go, all three connections go to the second row light just make sure you connect them to the proper terminals.
Click image to enlarge 2015 90 XS CSW TDCi - Beautiful 2007 110 XS DCPU - An itch that needed scratching 2005 90 Td5 XS CSW - Utterly brilliant 2001 Discovery 2 ES Auto - A phase I went through 1996 90 Tdi CSW - Uber reliable 1989 90 2.5 Petrol Hardtop - My first proper Landy 1985 Range Rover Vogue V8 -Troublesome |
17th Jun 2014 8:04pm |
Bristol 90XS Member Since: 31 Oct 2010 Location: North of Bath Posts: 223 |
Thanks will check again, that is how I have it wired aside from I am using crimps...
Hopefully I can get to the wiring without taking the head lining down again Now to wire up the vanity mirror... Any know if it is the purple or the white/purple that has permanent live? Currently they both seem to be live? Thanks James |
17th Jun 2014 8:31pm |
I'd suggest flicking the switch on the light to turn it on (with the doors shut) and see which contacts are supplying the feed to the switch in that position. 2015 90 XS CSW TDCi - Beautiful
17th Jun 2014 8:37pm |
