Home > Puma (Tdci) > QT diffguard fitting
Page 3 of 4 <1234>
lrmaniac
Portugal 2010 Defender 110 Puma 2.4 DCPU Keswick Green
re-using this topic.....
just fitted my QT diff guards yesterday, and there were two big bolts bolts to fit don't know where...Well I think they were to fit where that red rectangle is , but I don't have any holes there....
Did LR changed the diff design? I didn't read anywhere in the instructions that I had to drill a hole there... Mr. Green Regards
Joao
'10 Land Rover Defender 110 CC
'08 BMW F800GS
'64 SIIA Forward Control
'69 SIIA 109 ZA CKD
_____________________________________________
You have the right to remain silent. Anything you say will be misquoted, then used against you.
Post #198995 4th Jan 2013 7:37pm
Lorryman100
That guard just doesn't look as if it is meant for that diff. I went out and took a couple of pics of mine which are fitted to a 110 to show the bolts and just how close the slider front sits to the propshaft.
Spot the dogs?
HTH Brian.
Post #199035 4th Jan 2013 8:42pm
lrmaniac
that is strange....but even if that was the case (wich I don't thin it is, maybe the diff guard design changed a bit in the meantime), I don't have those holes in my diff to fit those large bolts you have... Question Regards
Joao
'08 BMW F800GS
'69 SIIA 109 ZA CKD
Post #199047 4th Jan 2013 9:01pm
Lorryman100
The QT website lists the same rear guard for both the 110 and 130? I can't really tell with your picture but did you have to undo the bottom 3 nuts on the diff to slide the guard on before tightening? To me it doesn't look as if it is sitting snug up against the bottom of the diff. Confused
As to the holes not being present, are they on the other side of the diffs on LHD? Are they there but filled in with mud etc.?
Brian.
Post #199060 4th Jan 2013 9:18pm
lrmaniac
Brian.
I did had to undo the 3 bolts at the bottom to fit it (but my pic is in fact strange, as I don't see the guard behind the bolts! edit: just went downstairs and checked - it's bolted behind the bolts)... and two on top to fit the upper bracket...As for the holes, there is a some sort of flat rectangle on there, as if the holes had been filled...but there was no mud...I cleaned it to check that.... Neutral ...did not really looked on the other side to check if there were holes on the right side of the diff (edit: just went downstairs and checked - there are no holes on either side) ...But according to their website, from 2003 onwards there are no diferences between the back diff guards(110 like mine, or 130), not even regarding LHD or RHD...if I read it right.... Question Regards
Joao
'08 BMW F800GS
'69 SIIA 109 ZA CKD
Post #199068 4th Jan 2013 9:27pm
BigRuss
Lr, my rear diff is the same asa yours (no holes).
I haven't fitted the guard yet and as I got the guards second hand I havent contacted QT to Land Rover about it. Russell
2011MY 110 XS USW Black
Post #199083 4th Jan 2013 10:15pm
Mote
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Santorini Black
Can't comment on the fact you have no holes on the rear diff. The puma guard would only be safely fitted if both those fittings are made. Don't feel you can get away without fitting both of these bolts into place. Can you imagine if one came off on the motorway and went bouncing into the car behind?
My experience of fitting these seriously solid guards was: the front was a pig, the light top plate needs to be bent a little to meet the guard along with a jack under the guard itself. A pig but doable. The rear guard needed one of those top two holes filed out slightly (only .5mm or so), and the two holes in the diff case needed the thread cleaning out carefully with a tap before the bolt would go in.
Awesome guards but took longer to fit than expected. I also don't like the way the front just touches the bottom of the diff pan, that will trap wet muck and eventually cause corrosion I think.
Post #199183 5th Jan 2013 3:06pm
Lorryman100
As long as the cast block is present on the diff, you could always drill and tap new holes. I could take one of the bolts out and measure the depth of the holes in mine if it would help? Also when I fitted the rear guard I had to ream out one of the side fixing holes slightly to get it to fit. Plus the middle slot for the diff nut was a right pain to get at to tighten once the guard was on.
Brian.
Post #199196 5th Jan 2013 4:33pm
lrmaniac
I believe that the guard is secure, despite not having those screws fitted...if it gets knocked maybe it will come off...you have a point there...
As for fitting, it all went well, there was no problem fitting both guards...apart from having to stop and think where/how would those screws be fitted... Razz
It was not easy....luckily the friend who helped me works with stuff like that for a living, so he had the right tool to make it easier, although he mentioned that when he was under the car... Mr. Green
I checked today at daylight, and I do not have those holes! I also guess that that place is solid, so I could drill two holes there... Confused just don't know how...My friend that helped me lives 350km away, and my vacation is over and I'm back at home, so going there on purpose it's quite expensive!
And how can you/me measure the hole size? by the lenght of the screw that should be there? And it will be safe to drill the diff? Neutral
I'll get in touch with QT, maybe they have a solution....Although I bought those guards almost two years ago... Embarassed ....and only fit them this week... Regards
Joao
'08 BMW F800GS
'69 SIIA 109 ZA CKD
Post #199254 5th Jan 2013 7:32pm
jst
my understanding is that the P38 diffs that were kicking about at LR had the holes and went into early Pumas, the later PUMAs had same diff but newly made and didnt have the holes in them.
My first 110 had the holes (58 plate) current one 60 plate doesnt. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #199639 7th Jan 2013 10:24am
quentin
Australia 2004 Defender 110 Td5 SW Alpine White
My QT Defender front diff guard just arrived, bit of a puzzle, there is only one hole in the top part, is it supposed to have two holes in the top ?? per images below
thanks in advance
Post #200434 10th Jan 2013 12:12am
BigRuss
thats normal, it allows for slight adjustment/tolerences Thumbs Up Russell
Post #200444 10th Jan 2013 6:32am
lrmaniac
Mine is 2010 model (assembled in March 2010), not quite an "early model". They should have tons of diffs left, if they were using them till the 2011 models! Razz
Wrote to QT, asking if they have a solution for it, besides drilling holes in the diff, but got no answer yet... Sad Regards
Joao
'08 BMW F800GS
'69 SIIA 109 ZA CKD
Post #200534 10th Jan 2013 2:46pm
quentin
Thanks Russ
your right about "tolerance" I had to leave the bolts loose and use a pry bar to get a hole to line up.
all fitted up great - front diff now wombat proof Thumbs Up
Post #200746 11th Jan 2013 6:12am
BigRuss
quentin wrote:
Thanks Russ
Thumbs Up Russell
Post #200747 11th Jan 2013 6:20am
Page 3 of 4 <1234>
