Home > Technical > Filler PLUG AND FUEL
expedition
Italy 2007 Defender 110 Puma 2.4 SW Keswick Green
Taken from the manual workshop Surprised (tanks dgardel)
The fuel filter is mounted on the rear right side panel, behind a flap access.
opened electrically via dashboard mounted switch that activates a solenoid release.
Surprised Surprised Surprised Surprised Surprised Surprised Surprised Surprised Surprised Surprised Surprised Vale
110 Td4 MY07 "E" Keswick Green
Post #23755 7th Feb 2010 11:54am
dgardel
Italy
i don't undertant..... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #23788 7th Feb 2010 7:20pm
willy eckerslike
United Kingdom 2007 Defender 110 Puma 2.4 HCPU Keswick Green
You are nit aloned Original Member Pie n Pea Club.
110 HCPU Tipper
Post #23792 7th Feb 2010 8:28pm
Chunk
United Kingdom 2010 Defender 110 Puma 2.4 XS CSW Stornoway Grey
willy eckerslike wrote:
You are nit aloned
Rolling with laughter
Post #23880 8th Feb 2010 9:15pm
o4dn
France 2009 Defender 90 Puma 2.4 SW Alaska White
Re: Filler PLUG AND FUEL
I am using a simple cover from defendoor.co.uk, it's cheap, efficient and reliable - Admittedly, I do not activate it from the dashboard Rolling with laughter yet it does the job...
Post #23902 9th Feb 2010 8:29am
Naks
Ordered mine, should arrive soon Smile
I think that OP is referring to is something similar to what the Disco2 had. You have to switch off the vehicle, then press the button for the filler to open.
Post #23903 9th Feb 2010 8:45am
