![]() | Home > Technical > Filler PLUG AND FUEL |
expedition Member Since: 11 Sep 2009 Location: Vercelli-ITALY Posts: 75 ![]() ![]() ![]() |
Taken from the manual workshop
![]() The fuel filter is mounted on the rear right side panel, behind a flap access. opened electrically via dashboard mounted switch that activates a solenoid release. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() 110 Td4 MY07 "E" Keswick Green |
i don't undertant..... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
You are nit aloned Original Member Pie n Pea Club.
110 HCPU Tipper |
Chunk Member Since: 19 Oct 2009 Location: County Durham Posts: 154 ![]() ![]() ![]() |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2661 ![]() ![]() ![]() |
Ordered mine, should arrive soon ![]() I think that OP is referring to is something similar to what the Disco2 had. You have to switch off the vehicle, then press the button for the filler to open. |
