Home > Technical > Filler PLUG AND FUEL |
expedition Member Since: 11 Sep 2009 Location: Vercelli-ITALY Posts: 75 |
Taken from the manual workshop (tanks dgardel)
The fuel filter is mounted on the rear right side panel, behind a flap access. opened electrically via dashboard mounted switch that activates a solenoid release. Vale 110 Td4 MY07 "E" Keswick Green |
7th Feb 2010 10:54am |
i don't undertant..... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
7th Feb 2010 6:20pm |
willy eckerslike Member Since: 15 Jun 2009 Location: North yorks Posts: 1789 |
You are nit aloned Original Member Pie n Pea Club.
110 HCPU Tipper |
7th Feb 2010 7:28pm |
Chunk Member Since: 19 Oct 2009 Location: County Durham Posts: 154 |
8th Feb 2010 8:15pm |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2651 |
Ordered mine, should arrive soon I think that OP is referring to is something similar to what the Disco2 had. You have to switch off the vehicle, then press the button for the filler to open. |
9th Feb 2010 7:45am |
