![]() | Home > In Car Electronics > Focal |
RobKeay Member Since: 19 Jul 2009 Location: Stafford Posts: 1591 ![]() ![]() ![]() |
Focal Access A3 165mm Speaker System
Cat code: 213905 Are these any good?? |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20644 ![]() ![]() |
165mm won't be a straight swap either, a no go on the front and only the rear with speaker panel modification. TheThunder Rollsπ¬π§πΊπΈ
β½οΈπ’οΈβοΈπ§°πͺ |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1434 ![]() ![]() ![]() |
They need to be all together Steve otherwise will just sound awful
Very true which IMO is pretty pointless to the rear anyway. TheThunder Rollsπ¬π§πΊπΈ
β½οΈπ’οΈβοΈπ§°πͺ |
Well mud sell the conversion for the rear.
Would the sound really be no better than the standard. It will come fitted with the alpine sub and my parrot head unit. I was going to get the sound proofing fitted as well. |
It would be marginally better, but there is much better out there.
![]() β½οΈπ’οΈβοΈπ§°πͺ |
So spend the extra and get focal k2?
I would.
![]() ![]() β½οΈπ’οΈβοΈπ§°πͺ |
Rob,The kit you highlighted requires all 3 speakers to be mounted together so as the cross over seperates the different frequencies to the correct cone. Seperating them will spoil the sound, and no improvement will be noticed, probably sound worse
![]() ![]() ![]() Last edited by barbel jim on 29th Dec 2013 7:42pm. Edited 1 time in total |
No but they seem highly recommended on here and have heard good things about them.
Just spotted those while looking at offers on halfords site and seemed a good price. Which would you recommend it's a 110 I am getting. |
http://www.ebay.co.uk/itm/Focal-Polyglass-...3cbc2487f8 is what I have in front and rear of mine. Coupled with a sub the clarity is amazing
How did you make them fit in the dash.
For Focal details Jim is your man.
![]() Dash fitting involves careful planning but personally I would advise no bigger than 13cm TheThunder Rollsπ¬π§πΊπΈ β½οΈπ’οΈβοΈπ§°πͺ |
It involved a bit of cutting, but it is a TD5. I have looked at a puma, and been trying to persuade Steve to grow a pair and fit some
