Home > In Car Electronics > Focal
RobKeay
Focal
Focal Access A3 165mm Speaker System
Cat code: 213905
Are these any good??
Post #293892 29th Dec 2013 2:23pm
barbel jim
They would need mounting in close prximity to each other to work correctly ie 2 in the door tweeter on the dash. More suited to direct replacement in a euro box Thumbs Up They are also more of an entry level speaker Whistle Your not far off 4/5" K2 power money, or polly glass (which is what I have). Ideally imo you'll need a sub of some description to complement any speaker upgrade Thumbs Up
Post #293895 29th Dec 2013 2:37pm
165mm won't be a straight swap either, a no go on the front and only the rear with speaker panel modification. No Guts, No Glory.
🇬🇧ðŸ´ó §ó ¢ó ¥ó ®ó §ó ¿ðŸ´ó §ó ¢ó ·ó ¬ó ³ó ¿ðŸ´ó §ó ¢ó ³ó £ó ´ó ¿ðŸ‡®ðŸ‡ªðŸ‡ºðŸ‡¸â›½ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª
Post #293904 29th Dec 2013 3:00pm
barbel jim
They need to be all together Steve otherwise will just sound awful
Post #293905 29th Dec 2013 3:02pm
Very true which IMO is pretty pointless to the rear anyway. No Guts, No Glory.
Post #293909 29th Dec 2013 3:08pm
RobKeay
Well mud sell the conversion for the rear.
Would the sound really be no better than the standard. It will come fitted with the alpine sub and my parrot head unit. I was going to get the sound proofing fitted as well.
Post #293984 29th Dec 2013 7:09pm
It would be marginally better, but there is much better out there. Thumbs Up No Guts, No Glory.
Post #293987 29th Dec 2013 7:18pm
RobKeay
So spend the extra and get focal k2?
Post #293988 29th Dec 2013 7:21pm
I would. Thumbs Up Of course good things normally are more expensive. Rolling Eyes Is a Focal your only option? No Guts, No Glory.
Post #293991 29th Dec 2013 7:31pm
barbel jim
Rob,The kit you highlighted requires all 3 speakers to be mounted together so as the cross over seperates the different frequencies to the correct cone. Seperating them will spoil the sound, and no improvement will be noticed, probably sound worse Rolling Eyes K2's are the ultimate, but as I said I have the polly glass that are the same money as what you are looking at Whistle IMO Focal is the way to go, there are alot forum users already converted Thumbs Up
Post #293994 29th Dec 2013 7:41pm
RobKeay
No but they seem highly recommended on here and have heard good things about them.
Just spotted those while looking at offers on halfords site and seemed a good price.
Which would you recommend it's a 110 I am getting.
Post #293995 29th Dec 2013 7:42pm
barbel jim
http://www.ebay.co.uk/itm/Focal-Polyglass-...3cbc2487f8 is what I have in front and rear of mine. Coupled with a sub the clarity is amazing Mr. Green Ideally you want componants up front (Like these) but could get away with co axials in the back. Componants are better as the highs don't fade if you play it long and loud. Dynamat is a well worth investment in itself. It will keep the music IN as well as unwanted noise Out Thumbs Up
Post #294003 29th Dec 2013 8:01pm
RobKeay
How did you make them fit in the dash.
Post #294010 29th Dec 2013 8:37pm
For Focal details Jim is your man. Thumbs Up
Dash fitting involves careful planning but personally I would advise no bigger than 13cm No Guts, No Glory.
Post #294016 29th Dec 2013 8:48pm
barbel jim
It involved a bit of cutting, but it is a TD5. I have looked at a puma, and been trying to persuade Steve to grow a pair and fit some Laughing With a spacer it'll be no problem. The other alternative is the 4" K2's which are about another £30. As I said the one's in the back don't need to be so fancy, but well worth it Whistle
Post #294018 29th Dec 2013 8:53pm
