Home > In Car Electronics > Focal |
RobKeay Member Since: 19 Jul 2009 Location: Stafford Posts: 1588 |
Focal Access A3 165mm Speaker System
Cat code: 213905 Are these any good?? |
29th Dec 2013 2:23pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20540 |
165mm won't be a straight swap either, a no go on the front and only the rear with speaker panel modification. No Guts, No Glory.
🇬🇧ðŸ´ó §ó ¢ó ¥ó ®ó §ó ¿ðŸ´ó §ó ¢ó ·ó ¬ó ³ó ¿ðŸ´ó §ó ¢ó ³ó £ó ´ó ¿ðŸ‡®ðŸ‡ªðŸ‡ºðŸ‡¸â›½ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª |
29th Dec 2013 3:00pm |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1431 |
They need to be all together Steve otherwise will just sound awful
29th Dec 2013 3:02pm |
Very true which IMO is pretty pointless to the rear anyway. No Guts, No Glory.
29th Dec 2013 3:08pm |
Well mud sell the conversion for the rear.
Would the sound really be no better than the standard. It will come fitted with the alpine sub and my parrot head unit. I was going to get the sound proofing fitted as well. |
29th Dec 2013 7:09pm |
It would be marginally better, but there is much better out there. No Guts, No Glory.
29th Dec 2013 7:18pm |
So spend the extra and get focal k2?
29th Dec 2013 7:21pm |
I would. Of course good things normally are more expensive. Is a Focal your only option? No Guts, No Glory.
29th Dec 2013 7:31pm |
Rob,The kit you highlighted requires all 3 speakers to be mounted together so as the cross over seperates the different frequencies to the correct cone. Seperating them will spoil the sound, and no improvement will be noticed, probably sound worse K2's are the ultimate, but as I said I have the polly glass that are the same money as what you are looking at IMO Focal is the way to go, there are alot forum users already converted
29th Dec 2013 7:41pm |
No but they seem highly recommended on here and have heard good things about them.
Just spotted those while looking at offers on halfords site and seemed a good price. Which would you recommend it's a 110 I am getting. |
29th Dec 2013 7:42pm |
http://www.ebay.co.uk/itm/Focal-Polyglass-...3cbc2487f8 is what I have in front and rear of mine. Coupled with a sub the clarity is amazing Ideally you want componants up front (Like these) but could get away with co axials in the back. Componants are better as the highs don't fade if you play it long and loud. Dynamat is a well worth investment in itself. It will keep the music IN as well as unwanted noise Out
29th Dec 2013 8:01pm |
How did you make them fit in the dash.
29th Dec 2013 8:37pm |
For Focal details Jim is your man.
Dash fitting involves careful planning but personally I would advise no bigger than 13cm No Guts, No Glory. 🇬🇧ðŸ´ó §ó ¢ó ¥ó ®ó §ó ¿ðŸ´ó §ó ¢ó ·ó ¬ó ³ó ¿ðŸ´ó §ó ¢ó ³ó £ó ´ó ¿ðŸ‡®ðŸ‡ªðŸ‡ºðŸ‡¸â›½ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª |
29th Dec 2013 8:48pm |
It involved a bit of cutting, but it is a TD5. I have looked at a puma, and been trying to persuade Steve to grow a pair and fit some With a spacer it'll be no problem. The other alternative is the 4" K2's which are about another £30. As I said the one's in the back don't need to be so fancy, but well worth it
29th Dec 2013 8:53pm |
