Home > Puma (Tdci) > Audio system
Page 2 of 2 <12
MrFlips
Wales 2008 Defender 90 Puma 2.4 PU Santorini Black
Cheers Alex, Steve: I'll try both on the weekend and see whuch works best for me Thumbs Up Peter
2008 SWB Truck Cab
1952 80" Soft top
Post #23974 10th Feb 2010 12:42am
ay4alex
United Kingdom 2008 Defender 110 Puma 2.4 XS DCPU Java Black
I might try routing mine down to the cubby box, neat idea! 110 Tdci Double Cab
Post #24001 10th Feb 2010 5:10pm
Paul55
England 2008 Defender 90 Puma 2.4 XS CSW Santorini Black
MrFlips wrote:
Good choice draymond, my iDA-X305 arrived today Very Happy
I'm looking to have a go at fitting mine on the weekend, the main question that springs to mind is - is there somewhere obvious that everybody has their iPod connector exiting from behind the dash?
Would you adam and eve it, just had a quote for the same radio, will be putting my iPod touch on the left hand side of the dash clipping a Brodit mount to it. Thumbs Up
www.mountonus.com Cogito ergo sum
Post #24003 10th Feb 2010 5:36pm
Paul55
Peter, have you decided yet on where to fit your iPod, was going to attach mine on the left hand side of the dash with a brodit mount but I'm having second thoughts, is the iPod connection cable from the Alpine long enough to fit in the cubby box. Cogito ergo sum
Post #24331 14th Feb 2010 6:53pm
discocuzzy
Hi Paul, ive replaced my headunit with an Alpine and the cable is long enough, i just wanted it out of the way of prying eyes, therefore the cubby box seamed the best solution, i have a Mobile storage cubby that allows you to channel the cable underneath and up into the dash Thumbs Up You cannot teach stupid people to do clever things
Post #24332 14th Feb 2010 7:03pm
Paul55
Thanks for the info discocuzzy Thumbs Up Cogito ergo sum
Post #24333 14th Feb 2010 7:06pm
MrFlips
Hi Paul, I ended up putting it in the cubby box too. This works nicely in that the iPod is hidden out of view (as you don't need to touch it with the Alpine unit controlling it) and also it was the easiest option just to route the iPod cable through the gap at the bottom of the dashboard and then straight under the rubber mat (carpet if you've got a posh one). Peter
2008 SWB Truck Cab
1952 80" Soft top
Post #24336 14th Feb 2010 7:50pm
Paul55
Cheers Peter, Thumbs Up Cogito ergo sum
Post #24339 14th Feb 2010 8:41pm
Page 2 of 2 <12
