Home > Puma (Tdci) > Volume Control Valve - Ford part no?
Page 2 of 9 <123456789>
dilukabey wrote:
Guys, what makes you to replace the vcv? As far as i know there won't be any dtc's when the vcv is malfunctioned. What are the symptoms/signs that i should change the vcv? Cheers.
Any if the following:-
- Flat spots
- Poor acceleration
- Erratic tickover
- Hunting
- Failure to start
- Just about any other problem that incorrect fuelling can cause
... in the absence of a DTC suggests that the VCV is the culprit.
It is the presence of a fault in the absence of a DTC that suggests the VCV is the problem.
Post #599888 7th Feb 2017 5:50pm
dilukabey
2009 Defender 110 Puma 2.4 SW Keswick Green
Many thanks for your reply Blackwolf. I am thinking to change the vcv too. Only problem for me is to do the pilot learning as i doubt whether there are any mechanics who can do this for me in this part of the world. Can i run the car without pilot correction after vcv replcement with no halm?
Post #599891 7th Feb 2017 6:01pm
agentmulder
Kuwait
If your VCV is faulty the learning procedures for it (in it's original state) are already off Thumbs Up Solved the bowel problem, working on the consonants...
Post #599894 7th Feb 2017 6:48pm
Pinky
England 2011 Defender 110 Puma 2.4 DCPU Baltic Blue
blackwolf wrote:
Pinky wrote:
Just had mine done, changed the common rail sensor at the same time as I was advised to always change them as a pair. And yes, you must pilot learn after fitting. Be careful buying cheap parts as they may not pilot learn and then you're up the proverbial creek without a paddle!
Rolling with laughter
I'd advise that too if I was selling you the sensor!
The common rail sensor is much more reliable than the VCV. I am on VCV No 3 and still the original pressure sensor and relief valve at 203,000 miles.
It wasn't the seller that advised me, it was a friend who works on nothing but Transits and they get as many come back in for the sensor after the VCV that they always advise to change both, saves two visits!
Post #599901 7th Feb 2017 7:38pm
B4Lamb
Wales 2007 Defender 90 Puma 2.4 HT Galway Green
I have managed to get a VCV on order from UKDieselParts.com for £65 incl VAT and delivery and 1 year warranty. They seem to have a good reputation, I will find out soon won't I? Unless the valve is widely out I cannot see how it would not calibrate. My understanding is the valve opening is controlled from a Pulse Width modulated signal from the ECM, so it is proportionally controlled. So the calibration is all about how far it does open for a certain pulse width signal by measuring the output of the high pressure pump and the results are stored back in the ECM. From what I read there is production tolerance that is not precisely controllable hence the need to characterise the valve with the high pressure pump as a pair. I'm not certain I need a new pressure sensor in the end of the high pressure rail, the existing one seems to be generating sensible pressure values according to the diagnostics but I guess these could be some way out of calibration.
Thanks for all your help on this, Ill update when I have more results to share.
John (aka b4lamb) "You are never to old to learn something new"
Post #599953 7th Feb 2017 10:16pm
B4Lamb
Hi you best read this thread which gives details of the common symptoms.
Home > Puma TDCi > Eratic Idle especially when cold
John "You are never to old to learn something new"
Post #599963 7th Feb 2017 10:35pm
TopQ1967
Netherlands 2012 Defender 130 Puma 2.2 HCPU Buckingham Blue
agentmulder wrote:
Just did this, can be done in situ.
The only part I removed, I did by mistake - a tube came out of the vacuum pump, nothing but air in it and area I was working in was clean so no probs.
It's the tube with the silver sheath, made it a little easier. WSM states it can be undone no issues.
I used 1/4" socket with a hex adaptor on wobble extensions and a universal. Getting the bolts out and back in is actually easy, cleaning the gasket mating face and getting the valve in with gasket and o-ring tact and clean - that's the fiddle.
What is the hex size? I tried 3,5 and 4 mm 3,5 is to small, 4 mm seems to big.
How did you get a wrench there I tried various small (Snap-on) tools but I cannot go there due to cables and pipes.
Post #601462 13th Feb 2017 3:10pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Just checked the one I have kicking about and they are 5mm 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #601464 13th Feb 2017 3:22pm
TopQ1967
thank you!
Post #601467 13th Feb 2017 3:30pm
TopQ1967
No, 5 mm will not fit even 4 mm is slightly to big..
Is it in a 2.4 as tight as in a 2.2?
Non of the tinny Snap-on tools will fit, only a long hex key (presuming I have the right size) will do the trick. Otherwise I have to remove the inlet manifold completely. Sad
This is a long hex key in 4 mm that is to big in size..
Hardly any space available (and I have removed some tyraps already.
Post #601474 13th Feb 2017 3:57pm
TopQ1967
Ian, It is quite possible the thread size is 5mm. But what hex socket will fit in?
Post #601477 13th Feb 2017 4:05pm
ian series 1
The one i have fitted to a spare pump
Is 5mm hex.
It is easier to take inlet manifold off, and a simple job. 80" 80" 86" 88" 90"
Post #601479 13th Feb 2017 4:26pm
TopQ1967
Parhaps simple but a lot of work, for only a 2 screw sensor...
There is a bracket above the last bulkhead side bold that holds the inletmanifold. I cannot access the bolt ... grr..
Think I have to bleed the heater and remove the hoses to access the bottom of the inlet. Or is it secured with clips?
At the rear of the inlet manifold there is a tube secured with bolts too.
This is going to take some time... Anyone else faced the same problems? It looked so easy... swopping a sensor..
Post #601481 13th Feb 2017 4:50pm
TopQ1967
double post..
Post #601487 13th Feb 2017 4:57pm
What tools are you using fir the pilot learn? What is envolved with that?
I'm assuming if you have a tuned map, that needs to be changed back to standard map first.
Then proceed onto VCV change then the pilot learn, is that correct?
It possible combined with my other thread as Ian suggested that this might be my issue too, although just starting to be at least.
Are most of the issues related to engine cold and after starting or issues at all temps? Mines fine when warm but a bit temperamental when very cold. TheThunderRollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #601500 13th Feb 2017 6:06pm
