![]() | Home > Maintenance & Modifications > Wipac Crystal upgrade |
dondiddy Member Since: 13 Nov 2012 Location: Hamilton Posts: 224 ![]() ![]() ![]() |
Yes, these are the original factory fit headlights!
Shirty Carpet Member Since: 10 Nov 2013 Location: Essex Posts: 25 ![]() ![]() ![]() |
Many thanks for the swift reply - looks like I'll be doing this upgrade too then!
ChrisD90 Member Since: 14 Aug 2013 Location: Middle Earth Posts: 71 ![]() ![]() ![]() |
Those are the right Wipacs (Paddocks PM678) & the bulbs are standard H4 fitment so should be fine.
I removed the entire unit, took apart, fitted bulb then re-assembled. Not sure it could be done any other way. I was careful with re-assembly but my alignment was massively out. My advice - Do the swap yourself, it's pretty easy, then have the lights re-aligned at an MOT centre. Unless you have the equipment to do it yourself that is ![]() Range Rover Evoque |
Here's a pic of the Wipac Crystals fitted, with Osram Nightbreaker Unlimited bulbs (low beam) and also just fitted RDX LED sidelights. For the total sum of £80 this is a much better setup.
![]() Along with the new brunel grille / headlamp surrounds the front of my truck looks much smarter ![]() ![]() Click image to enlarge 2013 Defender 90 HT Range Rover Evoque |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20597 ![]() ![]() |
Very nice, I do like your 90.
![]() ⛽ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª |
