Home > Maintenance & Modifications > Wipac Crystal upgrade
Page 2 of 2 <12
dondiddy
Scotland 1998 Defender 90 300 Tdi ST Nato Green
Yes, these are the original factory fit headlights! Smile
Post #287292 3rd Dec 2013 11:56am
Shirty Carpet
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Corris Grey
Many thanks for the swift reply - looks like I'll be doing this upgrade too then!
Post #287293 3rd Dec 2013 12:04pm
Trevor Wright
Can I assume the Wipac Crystal units in the Paddocks link above and the quoted Osrams would be applicable to a 2008 2.4 Puma?
Also, what is involved in fitting the units whilst preserving the alignment. Can this be done without removing the surrounding plate?
Thanks Trevor Wright
'08 90 TDCi/TD4 XS SW
Post #287629 4th Dec 2013 2:54pm
ChrisD90
United Kingdom 2013 Defender 90 Puma 2.2 HT Corris Grey
Those are the right Wipacs (Paddocks PM678) & the bulbs are standard H4 fitment so should be fine.
I removed the entire unit, took apart, fitted bulb then re-assembled. Not sure it could be done any other way. I was careful with re-assembly but my alignment was massively out.
My advice - Do the swap yourself, it's pretty easy, then have the lights re-aligned at an MOT centre.
Unless you have the equipment to do it yourself that is Thumbs Up 2013 Defender 90 HT
Range Rover Evoque
Post #287633 4th Dec 2013 3:12pm
ChrisD90
Here's a pic of the Wipac Crystals fitted, with Osram Nightbreaker Unlimited bulbs (low beam) and also just fitted RDX LED sidelights. For the total sum of £80 this is a much better setup. Cool The colour temperature of the headlights / sidelights match well too.
Along with the new brunel grille / headlamp surrounds the front of my truck looks much smarter Thumbs Up
 2013 Defender 90 HT
Range Rover Evoque
Post #287915 5th Dec 2013 1:08pm
Very nice, I do like your 90. Thumbs Up GBR
⛽ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª
Post #287935 5th Dec 2013 2:52pm
Page 2 of 2 <12
