Home > Maintenance & Modifications > Wipac Crystal upgrade |
dondiddy Member Since: 13 Nov 2012 Location: Hamilton Posts: 224 |
Yes, these are the original factory fit headlights!
3rd Dec 2013 11:56am |
Shirty Carpet Member Since: 10 Nov 2013 Location: Essex Posts: 25 |
Many thanks for the swift reply - looks like I'll be doing this upgrade too then!
3rd Dec 2013 12:04pm |
ChrisD90 Member Since: 14 Aug 2013 Location: Middle Earth Posts: 71 |
Those are the right Wipacs (Paddocks PM678) & the bulbs are standard H4 fitment so should be fine.
I removed the entire unit, took apart, fitted bulb then re-assembled. Not sure it could be done any other way. I was careful with re-assembly but my alignment was massively out. My advice - Do the swap yourself, it's pretty easy, then have the lights re-aligned at an MOT centre. Unless you have the equipment to do it yourself that is 2013 Defender 90 HT Range Rover Evoque |
4th Dec 2013 3:12pm |
Here's a pic of the Wipac Crystals fitted, with Osram Nightbreaker Unlimited bulbs (low beam) and also just fitted RDX LED sidelights. For the total sum of £80 this is a much better setup. The colour temperature of the headlights / sidelights match well too.
Along with the new brunel grille / headlamp surrounds the front of my truck looks much smarter Click image to enlarge 2013 Defender 90 HT Range Rover Evoque |
5th Dec 2013 1:08pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20597 |
Very nice, I do like your 90. GBR
⛽ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª |
5th Dec 2013 2:52pm |
