![]() | Home > Puma (Tdci) > Gearbox tech bulletin |
defninety Member Since: 13 May 2010 Location: Warwickshire Posts: 38 ![]() ![]() |
In fact a quick google and they can be found:
http://www.rimmerbros.co.uk/Item--i-LR052893[/url] |
borderterrier Member Since: 09 Dec 2011 Location: Surrey Posts: 1677 ![]() ![]() ![]() |
Just had bit done and it makes a significant difference to gear shifts
Excellent, glad to hear it.
Mjibex Member Since: 21 Mar 2013 Location: Reading Posts: 288 ![]() ![]() ![]() |
What age is your car? Does it make the shift less stiff, more accurate, not grind, a combination of the above? Cheers Mark. |
Its a 10 month old 110 SW. Less grind, and more positive.
Cuthbert Member Since: 26 Oct 2013 Location: Up North Posts: 1535 ![]() |
Will all new models coming out the factory now come with this modification already done?
You would think so
Can't say for certain as adding additional components and processes to any manufacturing line is not welcomed with open arms. I would hope that these bushes are fitted as an interim action and then the next batch of brackets produced will hopefully have a revised hole clearance to negate the need for them - after all I'm sure JLR wants the highest level of build quality possible for the Defender! ![]() |
martinfiattech Member Since: 13 Nov 2013 Location: leicester Posts: 422 ![]() ![]() |
thanks to defninety for this information as mine is undergoing this very modification hope it fixes it, will let you know if it does not.......
That didn't last long, back to notchy gear shifts.
william8 Member Since: 03 Apr 2013 Location: Motherwell Posts: 259 ![]() ![]() ![]() |
It would be good to get a few peoples reviews on them. If i was on a computer i would buy a couple just now cause they are pennies. William
MartinK Member Since: 02 Mar 2011 Location: Silverdale (Lancashire/Cumbria Border) Posts: 2665 ![]() ![]() ![]() |
Has anyone done this themselves yet...was it easy? I may just do it myself rather than waste 2 hours taking it to a dealer... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
landybehr Member Since: 17 Apr 2013 Location: -D- Posts: 173 ![]() |
unfortunately the bulletin/.pdf metnioned a few postings ago is gone now.
Were details in it that make clear how to do the job as DIY ? (bet there were) Any chance to find it elsewhere ?? |
There's a link here
http://www.4x4community.co.za/forum/attach...1395836085 ![]() I have bought the parts (only a couple of quid from Dan at Duckworths), but not got round to doing it yet (maybe this weekend) Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
