110 rear seat belt, help needed
Having trouble locating one of these, as you can see end is missing and due an mot. The part is no longer available second hand no problem. Cheers Matt
12th Nov 2013 2:59pm
Tiger
I have a full set, not sure I'd want to split them though
12th Nov 2013 3:03pm
roel
Wil that be a MOT failure? In Holland that is OK as long as the system works. The plastic cover is only show. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001)
1997 Camel Trophy Discovery 300TDI (2001-2009)
2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts.
2003 90 Td5 (2009-now)
12th Nov 2013 3:05pm
I think that will be an MOT failure.
You should be able to get through the MOT if you physically remove the rear seat from the vehicle for the test - if there isn't a seat, you should't need a seatbelt. I have done this in the past, though it is possible that the MOT rules have since changed.
