Home > Td5 > 110 rear seat belt, help needed
randallised
Ireland 2005 Defender 110 Td5 XS CSW Java Black
Having trouble locating one of these, as you can see end is missing and due an mot. Sad The part is no longer available second hand no problem. Cheers Matt
Post #281586 12th Nov 2013 2:59pm
Tiger
I have a full set, not sure I'd want to split them though
Post #281589 12th Nov 2013 3:03pm
roel
Wil that be a MOT failure? In Holland that is OK as long as the system works. The plastic cover is only show. Twisted Evil Roel
2003 90 Td5 (2009-now)
Post #281590 12th Nov 2013 3:05pm
I think that will be an MOT failure.
You should be able to get through the MOT if you physically remove the rear seat from the vehicle for the test - if there isn't a seat, you should't need a seatbelt. I have done this in the past, though it is possible that the MOT rules have since changed.
Post #281598 12th Nov 2013 3:55pm
