Home > Td5 > 110 rear seat belt, help needed |
randallised Member Since: 30 Apr 2012 Location: Doolin Posts: 18 |
Click image to enlarge Having trouble locating one of these, as you can see end is missing and due an mot. The part is no longer available second hand no problem. Cheers Matt |
12th Nov 2013 3:59pm |
Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265 |
I have a full set, not sure I'd want to split them though
12th Nov 2013 4:03pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17231 |
I think that will be an MOT failure.
You should be able to get through the MOT if you physically remove the rear seat from the vehicle for the test - if there isn't a seat, you should't need a seatbelt. I have done this in the past, though it is possible that the MOT rules have since changed. |
12th Nov 2013 4:55pm |
