Home > Td5 > TD5 accelerator pedal free play
excossack
How much free play is there from the pedal at rest to the point you notice the revs increase? and is there a way altering this? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #275306 20th Oct 2013 5:40pm
landy andy
None, and no.
Got a pedal assembly on the bench (Ready to be sold) in the garage will check tomorrow.
Andy
Post #275387 20th Oct 2013 7:50pm
excossack
So what your are saying is that as soon as I start to press the pedal I should notice a change in revs? I guess I have around 5-10mm before anything happens 1999 Defender TD5 110
Regards
John M0VAZ
Post #275390 20th Oct 2013 7:57pm
landy andy
Yes. I'm sure in mine that as soon as you touch the pedal the revs increase.
Post #275393 20th Oct 2013 7:58pm
excossack
I will double check mine tomorrow but deffo some travel.
How would this affect the driving of the car? 1999 Defender TD5 110
Regards
John M0VAZ
Post #275396 20th Oct 2013 8:07pm
excossack
Can later pedals be used with a earlier TD5 ? Mine is a 1999 1999 Defender TD5 110
Regards
John M0VAZ
Post #275799 22nd Oct 2013 12:28pm
Early can be used with late, not sure about late with early. depends on your ECU i think, if it's an NNN then you'll be OK.
you will need a nanocom type thing to change the settings.
Post #275897 22nd Oct 2013 6:45pm
excossack
Cheers. I have six wires on the pedal if that helps. 1999 Defender TD5 110
Regards
John M0VAZ
Post #275916 22nd Oct 2013 7:50pm
landy andy
Six wires equals two track pedal, seven wires on mine, as is a three track.
Andy
Post #275922 22nd Oct 2013 8:03pm
excossack
Thanks Andy. 1999 Defender TD5 110
Regards
John M0VAZ
Post #275982 23rd Oct 2013 8:45am
Carlosbeldia
Columbia 2001 Defender 110 Td5 SW Epsom Green
I had the same problem (very common in MY99), just took TD5 Map Editor and increased throttle sensitivity around 25% in the low end and 10% from 2800 on....it's wonderful now. MY02 don't have this issue, their pedal is better...
Post #276290 24th Oct 2013 11:38am
excossack
Mmm interesting. So one method is to remap the car I guess. (assuming the pedal is not faulty) I need some else with a 1999 TD5 six wire pedal to see how much free-play there is. 1999 Defender TD5 110
Regards
John M0VAZ
Post #276328 24th Oct 2013 2:14pm
Carlosbeldia
Usually I used to have around 1 cm of free play before anything happen in my car, was really bad. I changed my ECU for a NNN120, not remapped, just a plain 110 EU2 map, but really BIG improvement in smoothness and response. Specially with A/C on (I use it all the time), the throttle was really vague. The only "remap" I did was this in pedal response, rest have remained untoched.
Post #276375 24th Oct 2013 5:16pm
