Home > In Car Electronics > Osram Nightbreakers
Page 2 of 3 <123>
kipperthedog
They are.
Post #402458 26th Feb 2015 5:05pm
Anderzander
Smile
Post #402461 26th Feb 2015 5:23pm
Venomator
Fitted mine two weekends ago... Thumbs Up
And not been out in the dark since... Rolling with laughter
 Rog... Mr. Green
The GREEN One...
MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color]
Post #402520 26th Feb 2015 7:51pm
kipperthedog
"And not been out in the dark since..."
Post #402543 26th Feb 2015 8:19pm
HardCharger
kipperthedog wrote:
I have fitted them to the bog Wipac Quadoptics with the standard wiring and it makes a BIG difference. £15 well spent!! I wouldn't wait for a lamp to die...get the Nightbreakers in straightaway.
Hi kipperthedog,
Unfortunately I had to buy a set of Narva Contrast + bulbs as they gave out while I was on the road and had to the light bulb change inside the mall parking lot! Otherwise, some very ticket happy po-pos will be all over the truck when night time rolled around. That's why I said that if one of the Narva bulbs croaked, that's when I would get them as I've already spent the coin.
This being said, I'll get a set for the nightbreakers as a stand by set already just in case. They should be fine in their case (packaging), inside the truck, right?
Post #402624 27th Feb 2015 1:35am
kipperthedog
Nightbreakers seem to come in 2 types of packaging, a cardboard backed blister pack and a fancy hard plastic box. The plastic box is how mine came and this would be ideal for keeping a spare pair intact in the truck.
Post #402642 27th Feb 2015 8:29am
HardCharger
Good to know kipperthedog, now at least I know specifically what to ask for. I found an acquaintance selling Nightbreakers in the plastic box, I'll see if he has stock and get some pricing updates.
There's only one kind of Nightbreaker right? I heard that there was another version of Osram Nightbreakers floating around out there?
Post #402648 27th Feb 2015 8:53am
kipperthedog
"Unlimited" is the latest version I think. "Extreme" was the version before, and I think there was at least 1 before that.
Post #402657 27th Feb 2015 9:35am
HardCharger
Thanks kipperthedog! That'll definitely narrow things down on which version to get.
Post #402662 27th Feb 2015 9:42am
jimbob7
At least two types of nightbreakers,90% and unlimited 110%,I went for 90% ltd edition (gold plated,lol) As I assume the lower "performance" will last longer.Candle that burns twice as bright burns half as long etc.
Also a mate of mine fitted Nightbreakers to his Peugeot and it failed the MOT due to incorrect beam pattern,the tester demonstrated by fitting oem and the different acceptable pattern.
Personally I don't have a problem with OEM bulbs and headlamps,but it's a nice upgrade. Pov.spec,ftw. 2006, 110,TD5.
Post #402776 27th Feb 2015 3:02pm
AndyTunn
New Zealand 2008 Defender 90 Puma 2.4 SW Stornoway Grey
Anderzander wrote:
Thank you. Excuse my ignorance - are ours H4's ?
kipperthedog wrote:
They are.
The manual for my 08 Defender 90 lists the headlight bulbs as H7s - did they change the spec at some point?
Post #403205 1st Mar 2015 1:42am
kipperthedog
I would be surprised if they were h7s as these are single filament. Look at te back of your bulbs....3 contacts means definately h4.
Post #403242 1st Mar 2015 8:25am
Cupboard
The manual is wrong, it's a known issue. They are definitely H4s.
Post #403864 2nd Mar 2015 8:51pm
munch90
normally find when patterns wrong the bulb is in slightly out of line , think osram are the biggest manufacturer of bulbs and fitted to lots of makes of car from new
Post #403876 2nd Mar 2015 9:04pm
Birdy
France 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
I bought mine from Advanced Factors on here, some stainless bezels from I can't remember, after fitting them myself (five minute job) had the headlamps aligned by an MoT garage; so I know everything's perfectly adjusted.
My verdict: yes, an improvement, but nothing to wet my knickers about. Buy a set, have them in reserve so that when one of your originals burns out you can replace them both with an upgrade. But don't worry too much and, of course, having them as spares will mean that your factory-fitted ones will last the life of your vehicle.
Peter
Post #403901 2nd Mar 2015 9:50pm
Page 2 of 3 <123>
