Home > Puma (Tdci) > Rattle when rolling free at low speeds.
Page 2 of 2 <12
zone30
Belgium 2011 Defender 110 Puma 2.4 X-Tech LE Nara Bronze
It's gone again. Went for a week long offroadtrip and it's gone.
Did notice some different rattling, like loose springs, when going downhill but since back in flat country O haven't heard that again too.
Will keep a close ear to it as I'm still not convinced it's sorted. I'll have it looked at by a defwiz in a few weeks time. If he says it's normal, I'll leave it alone.
Would love to get a brand new clutch under warranty though Twisted Evil
Post #277771 29th Oct 2013 3:04pm
F
Belgium 2011 Defender 110 Puma 2.4 X-Tech LE Orkney Grey
Had the same issue,
its in fact the drum of the handbrake that isn't perfectly round.
When heating up, it starts to rattle.
Indeed it stops when you apply just a tiny bit of hand break
Post #277786 29th Oct 2013 3:52pm
zone30
It's back since this morning. Haven't heard it for a couple of days but apparently it did not sort itself.
Iow it'll need a closer look.
Post #277966 30th Oct 2013 7:44am
mk1collector
Could it be brake pad rattle? It's pretty common on the back
Post #278001 30th Oct 2013 11:17am
Honker
 2014 Defender 110 Puma 2.2 XS CSW Corris Grey
As something slightly different I also had a low speed rattle, from the front, could only hear while coasting and window down. Got slightly worse when turning at low speed.
Steering damper slightly loose.
Post #278013 30th Oct 2013 12:43pm
And1145
United Kingdom 2011 Defender 110 Puma 2.4 CSW Buckingham Blue
I had this, found to be the handbrake. I stripped it down and found a shoe was sticking and catching the drum which is slightly out of round. Lubed all the moving bits and it has never done it since !
Post #278120 30th Oct 2013 8:24pm
caribcat
2013 Defender 110 Puma 2.2 USW Aintree Green
This has happened on all 4 company Pumas. Very common. Anyone know a quick fix?
Post #278187 30th Oct 2013 11:38pm
mk1collector
You can get anti rattle clips for the front and the back but fronts are ridiculously expensive for what you get.
Post #278195 31st Oct 2013 12:04am
zone30
It went away by itself...
Post #289139 10th Dec 2013 1:06pm
Page 2 of 2 <12
