Home > Puma (Tdci) > Rattle when rolling free at low speeds. |
F Member Since: 09 Nov 2012 Location: Antwerp Posts: 1 |
Had the same issue,
its in fact the drum of the handbrake that isn't perfectly round. When heating up, it starts to rattle. Indeed it stops when you apply just a tiny bit of hand break |
29th Oct 2013 3:52pm |
zone30 Member Since: 07 Sep 2012 Location: Gent Posts: 669 |
It's back since this morning. Haven't heard it for a couple of days but apparently it did not sort itself.
Iow it'll need a closer look. |
30th Oct 2013 7:44am |
mk1collector Member Since: 17 Sep 2009 Location: West Yorkshire Posts: 6771 |
Could it be brake pad rattle? It's pretty common on the back
30th Oct 2013 11:17am |
Honker Member Since: 26 Jun 2011 Location: St Albans Posts: 353 |
As something slightly different I also had a low speed rattle, from the front, could only hear while coasting and window down. Got slightly worse when turning at low speed.
Steering damper slightly loose. |
30th Oct 2013 12:43pm |
And1145 Member Since: 04 Sep 2013 Location: Howden Posts: 30 |
I had this, found to be the handbrake. I stripped it down and found a shoe was sticking and catching the drum which is slightly out of round. Lubed all the moving bits and it has never done it since !
30th Oct 2013 8:24pm |
caribcat Member Since: 11 Jun 2009 Location: Anglesey Posts: 97 |
This has happened on all 4 company Pumas. Very common. Anyone know a quick fix? |
30th Oct 2013 11:38pm |
You can get anti rattle clips for the front and the back but fronts are ridiculously expensive for what you get.
31st Oct 2013 12:04am |
It went away by itself...
10th Dec 2013 1:06pm |
