Home > Puma (Tdci) > Coolant loss
Mjibex
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Loire Blue
Coolant loss
What is the general consensus on the expansion tank and pressure cap on the Puma.
Mine (2.2) seems to lose coolant from the cap - have had the cap changed under warranty - but don't think it has made any difference (maybe a little early to tell to be fair).
The cap is the same as a freelander 2 - which don't have problems - as far as I am aware?
Thoughts or experiences please (I have heard of a few issues but not many).
As far as I am concerned the coolant level on a properly operating system is check (but no top up required - unless a fault is present). So slightly miffed having to top up a 1500 mile car!!
Regards
Mark.
Post #274044 15th Oct 2013 6:01pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
Thought - might not be the cap. Have to checked the threaded part of the expansion tank to check for any deformities/damage? BM52
Post #274047 15th Oct 2013 6:07pm
Andreas Schuback
2.4 puma cap replaced and rechecked pressure still leaking turned out to be seam on the thread of expansion tank replaced under warranty by dealer no more problems since.
Post #274054 15th Oct 2013 6:30pm
Natlas
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Aintree Green
I lost about 10mm of water on my first long run on a very hot day, at the same time I noticed fresh orange tint on top nearside front of engine block near some plumbing. Stealer tested and found no leaks so I put it down to settling in of hose connections - perhaps? A couple of months later and nothing has changed so hopefully that was my one and only water issue.
Do you have orange staining anywhere? 2.2 90 XS
88" Series One
Old Norton Smile
Minerva
Post #274104 15th Oct 2013 9:02pm
Mjibex
Round the seam of the tank and the tank filler threads! New cap makes sod all difference!
Post #274461 17th Oct 2013 9:10am
Westo90
England 2003 Defender 90 Td5 CSW Oslo Blue
I had exactly the same problem "Mjibex" on my TD5 every 4 weeks i would check the coolant level and it would of dropped a fair amount but there was no signs of any leaks, i suspected the cap/thread on the expansion tank, one day after driving it i checked the level and i could her a faint hissing sound coming from the expansion tank undid the cap and the thread was wet, so stuck a thin layer of PTFE on the thread of the tank covered by a thin layer of silcone grease then never had a problem
hope that helps
Matt
Post #274546 17th Oct 2013 2:44pm
Shax
England 2010 Defender 90 Puma 2.4 XS CSW Stornoway Grey
I lost loads of coolant on my 2.4 last year,, The rear red engine lift bracket had cut the heater pipe... Quickly remedied by the dealers as the bracket is meant to be removed at PDI tiime... ... ,-------,
.. I [__][_]|__
.. I __ |"_|"__|
.. "(o)====(o)"
^^_-^-_^-^_^^^^^--^^^^
PAUL
G7ALW 14.200 USB
26FB458 / 27.275 SSB
Post #274683 17th Oct 2013 10:51pm
rossy
Don't panic just yet !
When I first bought mine 2 years ago I was concerned that I had to keep topping up the coolant as it always seemed to drop below the full level in the expansion tank. Then one of the helpful chaps on this forum suggested that I leave it alone for a bit and see what happens and hey presto it settled about 10mm under the full level and has remained there ever since ie - that was about 19 months ago. Very Happy
Post #274940 18th Oct 2013 9:48pm
dilukabey
2009 Defender 110 Puma 2.4 SW Keswick Green
Mine also simillar to Rosy. I guess it leaks through the threads of the tank/cap but once it goes down to certain amount from the full level then it stops leaking. Strange! Rolling Eyes
Post #275000 19th Oct 2013 6:06am
