Home > Maintenance & Modifications > Lightforce 170s - what fuses to uses?
Page 2 of 2 <12
BigWheels
The main fuse will be the one for headlamps/main beam. The auxilaries have their own fuse so that if they go, the headlamps will still work.
Should I uprate the main headlamp fuse as well, they use H4s at present? Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
Post #272906 11th Oct 2013 11:58am
Headlight fuse stays as is as no more power is being drawn from them than normal. No Guts, No Glory.
Post #272910 11th Oct 2013 12:10pm
smb
United Kingdom 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
BigWheels,
I would recommend you wire them via an Override switch that include a "on-warning". Some MOT stations are now checking the wattage of bulbs in spotlights and if illegal for road use are failing if not wired with an override.
Post #272913 11th Oct 2013 12:17pm
Page 2 of 2 <12
