Home > Maintenance & Modifications > Lightforce 170s - what fuses to uses?
BigWheels
Just bought some filters for my 170s & 140s (why are the clear dispersion (wider field than wide) ones not sold in the UK?)
Do I need to change the fuse for my current 55w auxilary lights, when having the 100w 170s replace them?
I see Roo lights have the same style graphics as Lightforce. Are Roo lights made by the same people? Which are better? Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
Post #272538 9th Oct 2013 11:55am
K9F
Current(Amps) = Power (wattage) divided by voltage.
Yes of course you need to change the fuse! Each 100 watt filament will draw approximately 8.5 amps in comparison to just under 5 amps each for your 55 watt ones. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #272539 9th Oct 2013 11:59am
BigWheels
So you recommend a 20? Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
Post #272541 9th Oct 2013 12:03pm
20A for two 100w lights. K9 is bang on the money.
Roos on mine at the same wattage and the fuse needs to be close to the battery too. No Guts, No Glory.
Post #272545 9th Oct 2013 12:15pm
SteveG
2005 Defender 90 Td5 CSW Belize Green
If wiring independently 10A is ok. If in one circuit it depends on no. of lamps
Post #272548 9th Oct 2013 12:17pm
BigWheels
Currently I have a separate fuse under the bonnet, so presume that would be it. It was fitted along with the auxilary lights. Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
Post #272557 9th Oct 2013 12:48pm
SteveG
You'll have to explain that one to me Smile
Post #272563 9th Oct 2013 1:12pm
Fuse needs to be close to the battery to protect the whole cable, fitting a fuse half way worse close to the item means the cable is not fully protected. The fuse is there to protect the cable not the item you intend to use.
For example any short in the cable (positive run) with the fuse near the battery the fuse will blow which will break the circuit and stop a possible fire. If you have that fuse half way along that wire or nearer the item I.e. The lights the fuse will only protect the cable nearer the lights and the whole rest of it is not protected at all so if it shorts between the battery and fuse there's nothing to stop it. Cable will go red rod burn off the insulation in a very fast timed melt anything in its patch and probably catch fire.
K9 please correct me if wrong.... No Guts, No Glory.
Post #272569 9th Oct 2013 1:53pm
barbel jim
^^^^ +1 That was what I was taught. It is not always phsically practical, but is best practice Thumbs Up Just look at house wiring, perfect example Whistle
Post #272574 9th Oct 2013 2:11pm
K9F
Customsteve is correct in principle it is always 'best practice' to ensure fuses are placed as close as possible to the power source. Nevertheless in the case of vehicle electrical power distribution the secondary fuses are normally protected themselves by a higher rated fuse protecting several different circuits or a mega fuse off the battery terminal itself.
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #272576 9th Oct 2013 2:14pm
I was thinking that but it will still be much much higher rated than the wiring is. No Guts, No Glory.
Post #272582 9th Oct 2013 2:28pm
K9F
Maybe so but the time it takes for a fuse to reach rupturing current with a direct short will be much quicker than the wire heating up and self combusting. In extreme cases the wire will vaporise or open circuit before ignition.
Quick look at the diagrams reveal relay coils for lighting protected by 5 amp fuse, headlamps by a 10 amp, subsequently protected by a larger 30 amp. The 30 amp would blow irrespective whether the 5 & 10 were in the circuit in a direct short scenario.
Post #272622 9th Oct 2013 5:35pm
Shocked No Guts, No Glory.
Post #272623 9th Oct 2013 5:40pm
K9F
With inadequate circuit protection of course. The wire/cable then in effect become the fuse. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #272624 9th Oct 2013 5:43pm
I have seen a wire glowing red hot on a shorting wire on an old mini, not something I would have ever wanted to own. You'd only have to touch the thing and the wiring would short all over the place. No Guts, No Glory.
Post #272627 9th Oct 2013 5:54pm
