Home > Maintenance & Modifications > Lightforce 170s - what fuses to uses? |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20497 |
Headlight fuse stays as is as no more power is being drawn from them than normal. No Guts, No Glory.
11th Oct 2013 12:10pm |
smb Member Since: 15 Jan 2013 Location: Cheshire Posts: 1232 |
BigWheels,
I would recommend you wire them via an Override switch that include a "on-warning". Some MOT stations are now checking the wattage of bulbs in spotlights and if illegal for road use are failing if not wired with an override. |
11th Oct 2013 12:17pm |
