Home > Puma (Tdci) > What mpg are peeps getting from there 2.2
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
I'm looking into a new defender but was curiouse as to what peeps are getting from them
Ex specially a 90 Whistle
Kind regards steve 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #271219 3rd Oct 2013 7:06pm
bob neville
Hi Steve
I get around 25mpg on my new 90, 4000 miles on the clock.
Just done 1,200 miles up to Scotland, touring around and back again, and still 25.
Tried Whistle to keep below 70 on the motorway but it made no difference.
2013 Defender 90 CSW - sold
Post #271242 3rd Oct 2013 8:04pm
big steve
Hmm ok so you getting 300 from a tank then 2015 2.2 tdci hardtop xs
Post #271244 3rd Oct 2013 8:08pm
noworries4x4
The new engine is churning out a constant 300miles every 52ltrs the old one was horrendous, please remember mine is fully loaded all the time, towing is a different story add a loaded Ifor and 200 a tank at best. If everything is under control you are not going fast enough.
Every Day 16 MY Discovery 4 Commercial Workshop and Escort Vehicle
Weekends 07MY L322 TDV8 Vogue SE
No Worries 4X4
Post #271245 3rd Oct 2013 8:10pm
RobKeay
I get between 290 and 320 a tank depending on use.
Post #271247 3rd Oct 2013 8:16pm
bob neville
Consistent 300 a tank. I fill around warning light time.
It has been improving and I expect to see some more improvement with some more miles on the clock.
Post #271249 3rd Oct 2013 8:19pm
Natlas
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Aintree Green
My readings from new....in a 90 SW
MPG
29.3
26.2
28.5
29.5
28.0
28.3
28.8
27.2
26.7
27.6
27.2
26.9
28.4
27.7
27.6
Cheers,
John 2.2 90 XS
88" Series One
Old Norton Smile
Minerva
Post #271255 3rd Oct 2013 8:34pm
Cheshire110
is a 90 tank smaller then?! i get near 400 (at calc'd 26.7mpg) from my 2.4 110 Cheers, David
Post #271286 3rd Oct 2013 11:10pm
Yes, a 90 tank is smaller. Darren
Post #271290 4th Oct 2013 5:09am
landy andy
Yes. 90 tank 60 ltrs, 110 tank 75 ltrs.
Andy
Post #271291 4th Oct 2013 5:10am
lukev01
England 2013 Defender 110 Puma 2.2 XS CSW Santorini Black
Too early to give you an accurate picture since it only has 600 on the clock so far.
But exactly 400 on the first tank with 67 litres, so 27 mpg from a 110 SW. 1970 Series 2A 88"
Post #271292 4th Oct 2013 5:31am
Photoguy1510
New Zealand 2013 Defender 110 Puma 2.2 SW Orkney Grey
Ok i get 8-8.6 assuming i have this correct at 4.546l per imp gal that be 22.7 -
24.4 mile/gal on a fully loaded 110 with roof racks and ladder on top. Or roughly 350 miles on a tank (66l) 2013 Orkney Grey 110 SE on order should be here on 20/04
Post #271317 4th Oct 2013 10:01am
tookaphotoof
Netherlands 2013 Defender 130 Puma 2.2 HCPU Santorini Black
With the 130 I get around 340 miles (70 l)
I can live with the fact my Transporter could make it 230+ miles easy on the same amount of diesel, and it's tank was 5 liter larger with a far more reliable meter.
The thing that annoys me about the Defender is its meter is far from reliable and last time it scared the sh!t out of me when it started to run rough less than 20 milies after the fuel warning light came on. Filled it up and guess what. Only 68 liters. I thought the 130 had a 75 liter tank?
Seriously considering a larger tank now as I love the Defender to bits, but the short range just annoys the hell out of me... Whistle
Post #271318 4th Oct 2013 10:15am
Photoguy1510
Dont forget to read the user manual, the defender will cut out 3 times to remind you its low on fuel and the final cutout will still leave 1 l of fuel in the tank. The gauge may be more accurate than you think it does this to prevent running the pump dry diesel act as a lubricant for the pump and this also prevents air from getting in the system.
From memory it brings on the light at 9l remaining then allows it to drop to 4l runs lean for 1l shuts down, simple restart runs lean for another 1l shuts down and finally runs lean for another 1l wont restart to protect the components. I assume the splutter is caused by running lean in the attempt to get more miles at the cost of comfort and power.
Its not a good idea to run a tank dead empty anyway there is a greater possibility to suck crap into the filters and worse water. Now if only the fitted a descent engine to the car it would be more economical like the 3l isuzu swap the turbo for a supercharger and viola reliability and boatloads of grunt, economical and no need for anti stall. 2013 Orkney Grey 110 SE on order should be here on 20/04
Post #271373 4th Oct 2013 6:49pm
nidge n
Had my 22 110 for 18 months now. I get a constant low 400 covering all driving types (from a little off road to motorways). I have to say that better quality fuel helps.
Post #271382 4th Oct 2013 7:33pm
