Home > Td5 > HELP PLEASE oil light stays on
ibexman
I have a 27000 mile td5 90 and the oil light stays on at idle . i have changed oil and both filters and oil pressure sensor any thoughts cheers Chris
Post #268507 22nd Sep 2013 10:19am
a short in the wiring ?
Post #268510 22nd Sep 2013 10:22am
ibexman
When i blip throttle it goes off may be idle is low ?
Post #268512 22nd Sep 2013 10:26am
ibexman
whoops
Post #268513 22nd Sep 2013 10:26am
Lou Sparts
Will the ECU let it idle low ? My money would be on a short in the wiring probably through a chaffed wire somewhere as the oil pressure switch is earth operated.
I had this problem on a non LR car some years ago where the oil light would come on at tickover. 2005 Td5 90 XS
Steve
Post #268514 22nd Sep 2013 10:32am
me@td5.org
2000 Defender 90 Td5 HT Epsom Green
Is your oil pressure low? Why assume it is an electrical fault? www.td5.org
Post #268521 22nd Sep 2013 10:51am
Laurie
Temporarily substitute a pressure gauge and see what readings you get.
Post #268522 22nd Sep 2013 10:53am
ibexman
I'm still using it I'm wondering if I should runs fine
Post #268525 22nd Sep 2013 10:58am
wizz80
i wouldnt be using it if it was me i have changed a few oil pumps on these with the same problem get a gauge on there asap
Post #270469 30th Sep 2013 6:02pm
Sphere
United Kingdom 2015 Defender 110 Puma 2.2 USW Keswick Green
I had this tried everything was the oil pump in the end. Mine was caused by the turbo failing and me not cleaning the sump properly. Expensive mistake but would be worse if the pump gives up.
Post #270484 30th Sep 2013 6:49pm
LR90XS2011
X2
Stop using it until you know the true pressure. I doubt the wiring DEFENDER 90 TDCI XS,
Post #270488 30th Sep 2013 6:56pm
ibexman
As tested by beadles land rover 6to8 psi at idle 75 psi at 4000 rpm
Post #270561 30th Sep 2013 9:03pm
dorstsmith2
United Kingdom 2003 Defender 90 Td5 HT Caledonian Blue
TD5 Engine pressure at idle cold 3.0 bar 43.5 lbf.in3 low oil pressure switch opening 0.2 - 0.6 bar 3.0 -8.8 ibf in3 Cool
Post #270596 30th Sep 2013 10:02pm
dorstsmith2
14 psi =1 bar
Post #270597 30th Sep 2013 10:04pm
wizz80
Yeah that pressure is to low get that oil pump changed asap
Post #270821 1st Oct 2013 8:36pm
