![]() | Home > Td5 > HELP PLEASE oil light stays on |
a short in the wiring ?
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2956 ![]() ![]() |
When i blip throttle it goes off may be idle is low ?
whoops
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 ![]() ![]() ![]() |
Will the ECU let it idle low ? My money would be on a short in the wiring probably through a chaffed wire somewhere as the oil pressure switch is earth operated.
I had this problem on a non LR car some years ago where the oil light would come on at tickover. 2005 Td5 90 XS Steve |
me@td5.org Member Since: 16 Jan 2011 Location: Warwick Posts: 856 ![]() ![]() |
Is your oil pressure low? Why assume it is an electrical fault? www.td5.org
Temporarily substitute a pressure gauge and see what readings you get.
I'm still using it I'm wondering if I should runs fine
wizz80 Member Since: 06 Dec 2012 Location: north devon Posts: 38 ![]() |
i wouldnt be using it if it was me i have changed a few oil pumps on these with the same problem get a gauge on there asap
Sphere Member Since: 26 Apr 2013 Location: Midlands Posts: 725 ![]() ![]() ![]() |
I had this tried everything was the oil pump in the end. Mine was caused by the turbo failing and me not cleaning the sump properly. Expensive mistake but would be worse if the pump gives up.
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3654 ![]() ![]() ![]() |
X2 Stop using it until you know the true pressure. I doubt the wiring DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy Last edited by LR90XS2011 on 1st Oct 2013 5:17am. Edited 1 time in total |
As tested by beadles land rover 6to8 psi at idle 75 psi at 4000 rpm
dorstsmith2 Member Since: 06 Aug 2012 Location: On the third rock from the sun in dorset Posts: 188 ![]() ![]() ![]() |
TD5 Engine pressure at idle cold 3.0 bar 43.5 lbf.in3 low oil pressure switch opening 0.2 - 0.6 bar 3.0 -8.8 ibf in3
14 psi =1 bar
Yeah that pressure is to low get that oil pump changed asap
