Home > Puma (Tdci) > exhaust white smoke |
It's normal it is vapor. Like mine when I run on the Alps. During a hill down the exhaust pipe came cold, and when you push the Throttle the warm gas produce vapor..... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
4th Jan 2010 4:25pm |
holdingpoint Member Since: 18 Aug 2009 Location: Como Italy Posts: 35 |
Thanks again dgardel!
Just to know, Is it happen also to you during a descent after a cold start up with engine cold and in 3th gear (engine brake) that some light blue smoke go out from exhaust? |
5th Jan 2010 12:51pm |
yes, mine smoke was white vapor.... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
5th Jan 2010 1:18pm |
It happen again! worst!
Today I went out with local club on the mountain unfortunately the weather was terrible heavy fog frozen rain, very dumpy weather! On they way back we went down on sky trail, I decided to engage first low gear, during the long descent (40 minutes)in order to use engine brake. After 15 minutes during descent the coolant temperature dropped to minimum. When finally I arrived at the descent end on plain, I disingaged low gear, and start too drive normally on normal street, after a couple of minutes a white dense smoke like a vapour train came out from exhaust, I stopped and also at the minimum smoke came out. It stops smoking and all turned normal when after some minutes when I accelerated. The smoke was white dense heavy burnt smell. I did all the ECU update and I changed two times EGR. Anyone soffered similar experience? |
7th Nov 2010 9:31pm |
Anyone with an idea of what it is?
9th Nov 2010 1:52pm |
Laurie Member Since: 22 Feb 2008 Location: Sussex, England Posts: 2897 |
Check your sedimenter for water.
9th Nov 2010 11:48pm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2414 |
NOt sure but quite normal on diesel engines. Some trucks use a blind-type cover when going downhill in cold climates. Anyway, the other day I heard a chap at the stealer complaining about the same issue (brand new). Puma 110" SW
10th Nov 2010 12:22am |
Peter Td4 Member Since: 23 Oct 2010 Location: Antwerp, Belgium Posts: 227 |
Couple of years ago when I was travelling with my camper (then on Ford base using same 2.4L engine) I also experienced this as I went over the Alps.
After a long climb to the summit of a pass (something like 2300m, don't remember exactly) we made a stop there for about one hour to have lunch. When we started driving again downhill the amount of white smoke was just increadible. Funny enough this was only visible when the accelerator was pressed down; when driving downhill and using the engine for braking nothing could be seen. I reported this to my garage (Ford) but never got any decent explanation as to what could have caused this. At that time the vehicle was also quite new (about one year). Never experienced this again . Note that the outside temperature at the mountain pass was pretty cold (but not freezing). Once the engine was warm again this white smoke stopped (could also have been because by then we reached much warmer air). |
10th Nov 2010 1:51am |
Peter when it happened with your camper, can you remember if the similar vapour white smoke was also bad smell, like when you burn a plastic panhandle?
10th Nov 2010 8:55am |
Even with normal temp on your engine, at downhill with 0 throttle, the amount of heat produced by minimum diesel injected producrs nearly no heat, so I guess it is cold diesel being coldy burned (plus vapour). I would no worry. I doubt any valve seal is wacked. Better ask a real diesel mechanic or LR customer. Puma 110" SW
10th Nov 2010 9:41am |
wyvern Member Since: 13 Dec 2009 Location: Cornwall Posts: 2101 |
this has started happening with our 07 110 ...
Thick white smoke with a plastic smell till it warms up -no loss of power, no use of oil / coolant air temp has been arround 0'c - but this is the first time I've seen it. It's very embarrasing pulling away and watching the world vanish behind in the mirror!! Is condensation all it is?? Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 |
22nd Dec 2010 9:09am |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3707 |
As mentioned have you checked for water in the fuel?
Click image to enlarge Click image to enlarge 130's have feeling's as well you know |
22nd Dec 2010 9:19am |
At 0C it's impossible...... May be a bug on ECU SW for the injection advance table Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
22nd Dec 2010 10:28am |
Hi Danelle how do I fix it?? or is it a dealer job.... Hi andrew - ok - How do we check for water in the traps ... (like where are the traps and how do I drain them,,,) I'm a bit green on the fixing stuff front..! festive best wishes Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 |
22nd Dec 2010 10:32am |
