Locate the fuel filter. Its behind a removable metal guard at the front of the drivers side (UK spec) rear wheel arch. Top Tip wash this area before you start looking
Remove the cover and you will see the fuel filter, it will look a bit like the filter shown in the pic below. Hold a clear glass container under the filter, undo the black knob at the bottom of the filter until fluid starts to run out (dont completely unscrew it). Allow about 1/2 pint to drain from the filter then tighten the black knob back up. Allow the contents to settle in the container take a picture and post here. http://www.defender2.net/forum/topic1636.h...uel+filter
Notes
Dont let too much fuel escape from the filter as you may need to bleed the system to re-start. Normally you will be OK.
