Home > Puma (Tdci) > Tdci diff's
landy andy
Tdci diff's
Can anybody tell me what diff's I have in a 10 reg 110 double cab?
Or how I can tell what they contain, 2pin, 4pin?
Andy
Post #266832 15th Sep 2013 9:20am
jst
3.54s
4 pin P38 rear
std LR front could be 2pin pre 5 Jul 10 build, 4 pin post 5 Jul 10 build Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #266882 15th Sep 2013 12:22pm
ericvv
Post #266897 15th Sep 2013 1:13pm
jst
sorry Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #266904 15th Sep 2013 1:58pm
ericvv
Post #266905 15th Sep 2013 2:00pm
I think it was pretty obvious.... Rolling Eyes
Post #266912 15th Sep 2013 2:39pm
Shep
2010 Defender 110 Puma 2.4 USW Orkney Grey
Jim - i think there was a quick edit! A man with no boat is a prisoner
Post #266916 15th Sep 2013 3:01pm
I know. prior to the edit I meant.
Post #266921 15th Sep 2013 3:13pm
ericvv
So to understand properly. My 110 SW is a late August or early September 2008 built, so a model year 2009.
Would this be a 2 or 4 pin front diff?
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #266929 15th Sep 2013 3:37pm
landy andy
I have a 4pin LSD. So I think the best plan is to put this in the Tdci rear, and the Tdci rear 4pin in the front.
Do we think that is the best option? As LSD's work well with TC and are stronger than standard parts.
Andy
Post #266949 15th Sep 2013 4:37pm
JR
Scotland 1984 Defender 90 200 Tdi SW Coniston Green
I'm not sure if that would work Landy Andy, I seem to remember hearing that the P38 rear diff has a longer pinion shaft.
But there again I might be wrong...
Post #267033 15th Sep 2013 8:01pm
landy andy
Oh, so may be better to put LSD in front axel then. Especially as it could be a two pin. (Not sure on date of truck, only got reg)
Post #267042 15th Sep 2013 8:25pm
P38 diff won't fit in the front axle.
P38 diff as used in 110 & 130 rear is a 4 pinion unit and although not a great diff is stronger that the 2-pinion Rover pattern front diff used in 90s and the earlier lwb vehicles.
Post #267092 15th Sep 2013 10:49pm
ericvv
Eric
Anyone? You never actually own a Defender. You merely look after it for the next generation.
Post #267096 16th Sep 2013 3:42am
landy andy
Eric
Pre 2010 so 2 pin
Andy
Post #267109 16th Sep 2013 6:57am
