![]() | Home > Td5 > Squealing under load |
appaloosadude Member Since: 17 Oct 2012 Location: Buckinghamshire Posts: 630 ![]() ![]() ![]() |
Exhaust manifold warped?
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5800 ![]() ![]() |
The squealing could be your exhaust manifold has warped. Check for the studs being loose/snapped, and sooty deposits at either end of manifold.
Andy |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6124 ![]() ![]() ![]() |
UJ's don't always vibrate, sometimes they really do squeel. a kind of cyclic squeel, as the thing rotates. try pumping some grease into them just to be sure. |
Landlord Member Since: 27 Oct 2009 Location: Hampshire Posts: 582 ![]() ![]() ![]() |
Interesting will check today - it is chipped so could be a possibility. Will also double check UJ's ![]() |
Martin 01 Member Since: 13 Feb 2012 Location: East Yorkshire Posts: 502 ![]() |
Having that same issue with mine.
Think the manifold is warped. Mine to has been remapped. Will be checking it this weekend. |
Another vote for a warped exhaust manifold, I'm afraid. Had the same on my wifes' old DII, twice! Darren
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 ![]() ![]() ![]() |
Can they be machined flat again or must you replace,just for future reference ! 2005 Td5 90 XS
Steve |
I think it depends how badly it's warped. We ended up with a new one as the manifold failed pretty catastrophically second time around, resulting in complete lack of power and a recovery home. Darren
It can be reskimmed and this is the recommended way, otherwise you fit new and it will warp, like the old one. Where as one that has already warped is less likely to again.
Andy |
Think I've found the problem - warped manifold, thought I would have to check it with feeler gauges - didnt need too was quite obvious
![]() Thanks for the replies, very helpful When taking the manifold off there were 2 gaskets between manifold and head, presume that is normal ? ![]() Click image to enlarge ![]() Click image to enlarge 2007 TD5 90 Hard Top |
rustyboxx Member Since: 08 Oct 2012 Location: Poole Posts: 548 ![]() ![]() ![]() |
I had the same problem not long after I had mine remapped. Exchanged the warped manifold for a secondhand one from my indie that had been skimmed but also had the webs between the manifold branches ground out too. Apparantly this helps avoid further warping. 15 months on and still going strong.
![]() 2007 110 XS DCPU - An itch that needed scratching 2005 90 Td5 XS CSW - Utterly brilliant 2001 Discovery 2 ES Auto - A phase I went through 1996 90 Tdi CSW - Uber reliable 1989 90 2.5 Petrol Hardtop - My first proper Landy 1985 Range Rover Vogue V8 -Troublesome |
Thor Member Since: 17 Dec 2011 Location: Didcot Posts: 446 ![]() ![]() ![]() |
Same issue with my TD5. When I had mine sorted by MID Engineering they also fitted something from JE Engineering to aid cooling, was only £60 or there abouts. Strong people are harder to kill and generally more useful!
Trossachs turbo Member Since: 14 Jul 2012 Location: Perthshire Posts: 21 ![]() ![]() ![]() |
If possible change studs to engineered type, suggest JE engineering,I had mine re skimmed new studs all ok,should only be one gasket
Presume OEM gasket is made of two thin pieces of metal pressed together because two pieces came off !
Will be ordering new manifold and gaskets tomorrow ![]() |
