Home > Td5 > TD5 cruise control kit
Page 2 of 2 <12
T1G UP
nickh90 wrote:
Someone fitted it to my TD5 90 before i bought it, but when they changed to the discovery ratios it no longer worked other than in 4th gear!
Be aware as I am not aware of a fix!?
so if you used D2 ecu then it should be programmed for the higher TB?
Post #56137 1st Feb 2011 10:18pm
Zinke
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
Yes in theory that would work, but ive not been able to get a discovery ECU to work on a defender yet. You can change the drive gear for the speedo in the transfer box to fool the ECU into thinking that the vehicle is going slower that it is but then your speedo is reading way under what it should and the mileage would be low too. Think its about 15% low.
The only true fix would be to see if somebody like Pete from BAS can make a map that would accept the disco transfer box and allow the cruise to work too. But ive been told its not something that can be does easily.
Pete.
Post #56288 2nd Feb 2011 7:33pm
Roald
Denmark
Can someone recommend me a kit? I have only found the cruise kit http://www.nakatanenga.de/ sells, is that a good one? Smile
Post #63600 13th Mar 2011 8:26pm
nakatanenga
Germany
We solved this problem times ago. We built an adjustable electronic device which is soldered into the cable to the ECU whih provides the speed pulses. The speedo will remain untouched and the ECU gets different signals so the CC works with D2 transfer boxes as well. WANTED:
SII or SIII in max 1.5k
Post #63627 14th Mar 2011 5:49am
Roald
Denmark
Nice. Is your installation guide only in German or?
Post #63628 14th Mar 2011 7:08am
nakatanenga
Germany
In english as well!
The D2 transfer speedo adaptor comes with a drawing which can be understood. WANTED:
Post #63658 14th Mar 2011 9:55am
ben_j85jty
United Kingdom 2002 Defender 110 Td5 XS DCPU Bonatti Grey
Interesting,
Does it work with D1 boxes as well? 2002 Defender 110 DC
Post #63666 14th Mar 2011 12:32pm
nakatanenga
Germany
To be honest, the device is a frequenzy divider, multipler.
It changes any input signal to different output signals.
So it can change speedo signals as well as revs or any other pulse.
We use it with Td5 and Pumas with extreme tire sizes to the correct speedo settings. WANTED:
Post #63725 14th Mar 2011 8:54pm
Couldn't find it in English on your site at all.... got a link???
Post #63728 14th Mar 2011 8:59pm
nakatanenga
Germany
Post #63731 14th Mar 2011 9:03pm
megatoad
United Kingdom 2006 Defender 110 Td5 XS CSW Zambezi Silver
Hi Zinke
Not sure if I alread sent you a pm this morning, but I was wondering if you are still doing the cruise control kits for the TD5, mine is an 06 with standard tyres and transfer box so should be OK
Do you crimp the terminal connections for plugging into the ECU connector?
I am seriously toying with the idea.
Julian He who dies with the most toys wins Smile
Defender 90 & 110, S1 80", Disco 1, S111 88
LRSOC & CVLRC
Post #232009 1st May 2013 1:35pm
Postmanpat
Ireland 2004 Defender 110 Td5 DCPU Bonatti Grey
CarMan wrote:
Zinke's kit is great - well worth doing
where can one get it ? Wink Postmanpat
Post #237426 21st May 2013 9:57am
Page 2 of 2 <12
