Home > Technical > Have I too much transmission wear.........
v8bobber
United Kingdom 2008 Defender 110 Puma 2.4 DCPU Java Black
My lovely 110 td5 (120k miles) suffers from a terrible "thump" when taking up drive.
I have changed the rear drive flanges, the rear bushes and changed the propshaft yesterday as this had a fair amount of play in the splines and the yokes. It has definitely improved but the thump is still there and in is excessive.
It has always been there and was hoping that I could engineer most of it out as I knew from previous vehicles that a bit of wear in all the transmission components can add to up to a vehicle that is very unpleasant to drive. I have had a crowbar on the A frame ball joint and there doesnt seem to be any play in it?
When I changed the propshaft I chocked the wheels and putting it in first gear decided to see how much wear was in it. Seems like a fair bit to me, see what you think.........
http://www.youtube.com/watch?v=HIKncRkkAgE
This is the rear diff play and it doesnt seem that bad?
Opinions please!
Dave
Post #262198 29th Aug 2013 3:57pm
rustandoil
I dont think i am seeing too much of a problem in those two videos, have a look at the ball joint on the top of the axle, this could give the symptoms you describe
Post #262218 29th Aug 2013 6:12pm
v8bobber
as per the original post I am not seeing any movement with the a frame, unless I am not checking it right
Dave
Post #262287 29th Aug 2013 9:17pm
v8bobber
Dave
Post #262288 29th Aug 2013 9:18pm
landy andy
Neither of those items have that much play, what about the front axle?
Andy
Post #262299 29th Aug 2013 9:46pm
v8bobber
What is the best way to test the front axle. There is a hell of a whine from what I think is the front
Dave
Post #262300 29th Aug 2013 9:47pm
landy andy
First is to check the drive flange on the diff, exactly the same as you did to the rear in your video.
Why only change rear drive flanges, not all four? Front ones ok?
I find these clonks are an accumulation of many warn items, most of the time.
Andy
Post #262308 29th Aug 2013 9:57pm
v8bobber
would jacking one front wheel off the floor do the trick?
Dave
Post #262309 29th Aug 2013 9:58pm
landy andy
Best would be to remove front prop, check joints on that, then check front axle drive flange.
Andy
Post #262310 29th Aug 2013 10:00pm
v8bobber
I forgot to mention that the front propshaft was recently renewed not long before i bought the vehicle, so it should be ok
Dave
Post #262311 29th Aug 2013 10:02pm
boxer
United Kingdom 1990 Defender 90 200 Tdi HT Coniston Green
HI CHANGE THE A FRAME BALL JOINT I had the same on my 200tdi 90 tried to find lift in the joint and couldn't so changed the diff, prop shaft bearings and still the knock, last chance was the a frame ball joint and that sorted it took me 1.5hrs and 35pound.
Post #263188 2nd Sep 2013 6:24pm
v8bobber
Hi,
Thanks for the reply. After discussion with a mate we have been thinking along the same lines despite not finding any visible wear in the ball joint.
I spoke to Ashcroft and they looked at the video I had taken and they thought that the amount of wear was minimal.
Thanks again,
Dave
Post #263229 2nd Sep 2013 8:36pm
ajps72
2001 Defender 110 Td5 SW Chawton White
Hello, just changed the flanges and one semiaxle on the rear and the clunk noise is totally gone.
I lifted one wheel and found that the tyre move 2-3 inches before it locked.
Hope it works for you. Augusto
Defender 110 TD5 2001
Discovery 4 TDV6
Post #263280 2nd Sep 2013 10:42pm
v8bobber
I'd already changed the flanges on the back although I did notice that the ones on the front aren't great either and will change them when I get the chance
D
Post #265368 10th Sep 2013 8:19pm
v8bobber
D
Post #265369 10th Sep 2013 8:19pm
