Home > Technical > Have I too much transmission wear......... |
v8bobber Member Since: 26 Aug 2012 Location: pembrokeshire Posts: 445 |
My lovely 110 td5 (120k miles) suffers from a terrible "thump" when taking up drive.
I have changed the rear drive flanges, the rear bushes and changed the propshaft yesterday as this had a fair amount of play in the splines and the yokes. It has definitely improved but the thump is still there and in is excessive. It has always been there and was hoping that I could engineer most of it out as I knew from previous vehicles that a bit of wear in all the transmission components can add to up to a vehicle that is very unpleasant to drive. I have had a crowbar on the A frame ball joint and there doesnt seem to be any play in it? When I changed the propshaft I chocked the wheels and putting it in first gear decided to see how much wear was in it. Seems like a fair bit to me, see what you think......... http://www.youtube.com/watch?v=HIKncRkkAgE This is the rear diff play and it doesnt seem that bad? Opinions please! Dave |
29th Aug 2013 3:57pm |
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 738 |
I dont think i am seeing too much of a problem in those two videos, have a look at the ball joint on the top of the axle, this could give the symptoms you describe
29th Aug 2013 6:12pm |
as per the original post I am not seeing any movement with the a frame, unless I am not checking it right
Dave |
29th Aug 2013 9:18pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5699 |
Neither of those items have that much play, what about the front axle?
Andy |
29th Aug 2013 9:46pm |
What is the best way to test the front axle. There is a hell of a whine from what I think is the front
Dave |
29th Aug 2013 9:47pm |
First is to check the drive flange on the diff, exactly the same as you did to the rear in your video.
Why only change rear drive flanges, not all four? Front ones ok? I find these clonks are an accumulation of many warn items, most of the time. Andy Last edited by landy andy on 29th Aug 2013 9:58pm. Edited 1 time in total |
29th Aug 2013 9:57pm |
would jacking one front wheel off the floor do the trick?
Dave |
29th Aug 2013 9:58pm |
Best would be to remove front prop, check joints on that, then check front axle drive flange.
Andy |
29th Aug 2013 10:00pm |
I forgot to mention that the front propshaft was recently renewed not long before i bought the vehicle, so it should be ok
Dave |
29th Aug 2013 10:02pm |
boxer Member Since: 12 Jun 2011 Location: north yorkshire Posts: 48 |
HI CHANGE THE A FRAME BALL JOINT I had the same on my 200tdi 90 tried to find lift in the joint and couldn't so changed the diff, prop shaft bearings and still the knock, last chance was the a frame ball joint and that sorted it took me 1.5hrs and 35pound.
2nd Sep 2013 6:24pm |
Hi,
Thanks for the reply. After discussion with a mate we have been thinking along the same lines despite not finding any visible wear in the ball joint. I spoke to Ashcroft and they looked at the video I had taken and they thought that the amount of wear was minimal. Thanks again, Dave |
2nd Sep 2013 8:36pm |
ajps72 Member Since: 08 Jan 2012 Location: Lima Peru Posts: 105 |
Hello, just changed the flanges and one semiaxle on the rear and the clunk noise is totally gone.
I lifted one wheel and found that the tyre move 2-3 inches before it locked. Hope it works for you. Augusto Defender 110 TD5 2001 Discovery 4 TDV6 |
2nd Sep 2013 10:42pm |
I'd already changed the flanges on the back although I did notice that the ones on the front aren't great either and will change them when I get the chance
D |
10th Sep 2013 8:19pm |
D |
