Home > Maintenance & Modifications > JW Speaker Led Lamp corrosion
Page 3 of 6 <123456>
Hifonics
2013 Defender 110 Puma 2.2 USW Corris Grey
I cant see how corrosion within the warranty period can be acceptable on anything.
Part of the sales of goods act explicitly covers the item of being of satisfactory quality and this includes cosmetic defects. If the warranty is for four years then I would expect the item not to have significant corrosion within that time.
I am certainly going to put my purchase on hold until I see how these issues play out.
Post #259632 18th Aug 2013 3:14pm
GUM97
Well, this thread has certainly been an eye opener! It's out me off purchasing or even recommending them until these problems have been resolved! An engine to TDi for!
Post #259646 18th Aug 2013 4:21pm
K9F
I would personally look closer at the vehicle you all chose to purchase with a three year corrosion warranty and six year paint neither of which is worth diddly squit after the three year point! Whistle
Rolling with laughter Rolling with laughter If you go through life with your head in the sand....all people will see is an ar5e!!
Post #259676 18th Aug 2013 7:09pm
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
Even Land Rover have a warranty that covers some forms of corrosion. Corrosion that does not affect performance during the 4 years of the headlights warranty, nonetheless would significantly effect re-sale value and could be responsible for failure once the warranty period is up. Not a good situation for something costing close to a £1000/pair.
My original Land Rover headlights have no corrosion apart from the retaining rings which are now stainless steel, and those rings are still used for the JW Speaker headlights. I think I'll keep to my Crystals and Osram Nightbreakers for the time being. Sad LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #259680 18th Aug 2013 7:16pm
dgardel
Italy
 Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #259764 19th Aug 2013 6:37am
Kitoper
Switzerland
Gentlemen,
I have just had a chat with Eric and shown him the light supports I have for my Noldens. Instead of the rings being just stainless steel, mine are powder coated black and from Nakatanenga: link here
http://nakatanenga-tours.de/shop/article_B...RDEF-VA%26
The idea is that the powder coating on these rings would create a barrier between the stainless and the lamp, meaning no direct contact.
Post #259790 19th Aug 2013 8:31am
adafish
United Kingdom 1984 Defender 110 300 Tdi DCPU Stornoway Grey
Powder coating does that, you get the same with side steps, wheels carriers, nudge bars,lightbars..... Its not going to effect the use of the light is it... Rolling Eyes Putting Dreams on Drives at JLR Solihull..
Post #259794 19th Aug 2013 8:52am
adafish
..........then what happens when the powder coating starts coming of the ring, you won't get a nice fit around the light either due to the coating, so....a bit of sanding will only lift what you've had done... Putting Dreams on Drives at JLR Solihull..
Post #259795 19th Aug 2013 8:54am
Kitoper
Switzerland
The Nakatanenga rings fit well on the noldens, and the quality is typical of Nak. I can try to take a picture if that would be useful.
Post #259820 19th Aug 2013 9:47am
Kitoper
Switzerland
Picture from the Nak site:
Post #259822 19th Aug 2013 9:50am
smb
United Kingdom 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
I know this might sound stupid and will probably upset a few on here, but is this the fault of the lights OR is it that they are being fitted on a Defender???
Before you try and dismiss this idea, there is a lot of vibration and movement in a Defender and in places you wouldnt think there should be, but this vibration and movement creates rubbing which no amount of protective coating is going to sort out. Look at some Stainless Steel and Galvanised fittings on Defenders whether factory fit or your fit and there will be a good chance you will see 'wear'. So if that doesn't do it then no powder coating, anodising, painting will be good.
Now I haven't got any of this corrosion that everyone is going on about, but then whenever I fit anything to the Defender whether it is aftermarket or just replacing I always put a layer of black engine gasket sealant between the two surfaces and I don't get any of these problems.
Just my penny's worth, but it is worth considering.....
Post #259835 19th Aug 2013 10:24am
adafish
..........same has whats fitted to mine, apart from bare SS, the coatings still going to come off them fella i'm afraid... Putting Dreams on Drives at JLR Solihull..
Post #259838 19th Aug 2013 10:34am
Kitoper
Switzerland
Then I can only hope the Nolden casing is different, and I will take a few other precautionary measures as suggested by SMB and others.
Post #259839 19th Aug 2013 10:36am
mobilecentre
If any body has a specific issue with a product they have bought directly from us then we are more than happy to look at it this has always been the case and always will.
Some of the issues posted on here are the first time I am aware of it so if no one has thought to bring it to my attention until now then I can only start to look at things now.
We have always had an open book policy on warranty returns and J W Speaker has the lowest rate of any of our LED lighting manufacturers and Blue Sea occupies the overall bottom slot for electrical devices - which happens to be the best place Thumbs Up
Post #259897 19th Aug 2013 3:05pm
dgardel
Italy
In My opinion the old 8700 corrosion problems are due to broken paint by the rings that Fit too with interference.
The evo ones suffers from the SS contact but a good anticorrosion grease solve the problems.
My car is full JWS led and the only problem that I had was from a direction Light that TIM (Mobile Centre) changed quickly.
The extended JWS warranty is a plus. Tim customer Service level is a win win plus. Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #259909 19th Aug 2013 4:35pm
