Home > Technical > nut rivet help!
Eduardo
nut rivet help!
Hi there...
I just bougth a mesh head lamp guard but obviosly I need to install it.
As far as I see the nut rivet system to fixed it, looks to be the best. But regretably the nut rivet tool is quite expensive here. I ordered one from USA but will arrive quite late (before Christmass)
Anybody knows a way to install this kind of rivet without using nut rivet tool?
Thanks for any suggestion Eduardo
Post #20373 17th Dec 2009 9:47pm
ponamore
United Kingdom 2015 Defender 110 Puma 2.2 USW Tonga Green
hi, just use a bolt and nut, run nut up bolt, fit rivnut on end of bolt,run nut back down to rivnut, insert in hole, hold head of bolt with spanner and tighten nut with second spanner this will expand rivnut.
Post #20376 17th Dec 2009 10:02pm
Nut & bolt the same size as the rivnut m6 m8 ? piece of plate with a hole drilled in the right size
screw nut and bolt together pass bolt thru plate attach rivnut
put rivnut in hole in car hold nut with spanner and tighten bolt until rivnut is firm back off and hey presto
Post #20377 17th Dec 2009 10:03pm
Eduardo
Thanks mates!
But I get one borrowed from a LR friend.
Cheers! Eduardo
Post #20384 17th Dec 2009 10:56pm
fekete
Here ED Thumbs Up
http://www.x-eng.co.uk/rivnut.asp NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #20387 18th Dec 2009 12:30am
But a tool its way quicker
Just a tip the RivNuts that come with LR stuff are crapp get your own Thumbs Up
Post #20391 18th Dec 2009 7:04am
alantd
fekete wrote:
Here ED Thumbs Up
Second this. You can make your own tool. Works perfectly in my experience (although I also bought one to same fiddling around all the time with spanners). One that started out as a 2.4 TDCi 110 XS
Post #20409 18th Dec 2009 12:03pm
Eduardo
Thanks to all of you! Eduardo
Post #20410 18th Dec 2009 12:07pm
