![]() | Home > Technical > nut rivet help! |
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2110 ![]() ![]() ![]() |
Hi there...
I just bougth a mesh head lamp guard but obviosly I need to install it. As far as I see the nut rivet system to fixed it, looks to be the best. But regretably the nut rivet tool is quite expensive here. I ordered one from USA but will arrive quite late (before Christmass) Anybody knows a way to install this kind of rivet without using nut rivet tool? Thanks for any suggestion Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
Nut & bolt the same size as the rivnut m6 m8 ? piece of plate with a hole drilled in the right size
screw nut and bolt together pass bolt thru plate attach rivnut put rivnut in hole in car hold nut with spanner and tighten bolt until rivnut is firm back off and hey presto |
Thanks mates!
But I get one borrowed from a LR friend. Cheers! Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
Here ED
![]() http://www.x-eng.co.uk/rivnut.asp NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY |
But a tool its way quicker
Just a tip the RivNuts that come with LR stuff are crapp get your own ![]() |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 ![]() ![]() ![]() |
Second this. You can make your own tool. Works perfectly in my experience (although I also bought one to same fiddling around all the time with spanners). One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
Thanks to all of you! Eduardo
