Home > Td5 > EGR blank kit FAIL
ttuck3r
Scotland 1999 Defender 90 Td5 HT Caledonian Blue
EGR blank kit FAIL
Well my EGR blank kit for my Defender TD5 arrived 2 days ago so i set about spraying penetrating oil on the appropriate bolts and continued for the two days, today i set about installing the kit and the inevitable happened, both bolts snapped flush with the manifold even with applying ample heat to areas and only using a small allen key as to not apply to much pressure. The rest of the day was spent trying to get the manifold off with the same problems occurring so i've admitted defeat and getting her towed to Strathearn engineering tomorrow..... Big Cry
Post #257333 8th Aug 2013 7:41pm
landy andy
Sorry to hear that, feel for you.....
Time for a drink Thumbs Up
Andy
Post #257343 8th Aug 2013 8:10pm
ttuck3r
Unnecessary quote removed
Thanks Dude, Whiskey on the rocks number 3 on route..
Post #257345 8th Aug 2013 8:12pm
johnnyd
Same happened to me when I tried to fit mine......but I could still drive it, cost me 200 quid Big Cry
JD 2008 TDCi 2.4 XS CSW
Post #257352 8th Aug 2013 8:25pm
ttuck3r
O man i can feel my wallet starting to sweat.. Shocked
Post #257356 8th Aug 2013 8:36pm
johnnyd
I don't think those two Allen bolts would ever come loose on a Defender over one month old Rolling with laughter
Post #257360 8th Aug 2013 8:40pm
kipperthedog
....I am really looking forward to fitting mine now.......
Someone who has fitted a few to Discovery 2s did advise me to spray with penetrating oil for a week or so (!) and then do the job carefully when the engine is warm and the manifold is therefore hot.
.......can't afford a disaster just now though!
Post #257584 9th Aug 2013 5:50pm
landy andy
Get the engine HOT, then tighten them slightly before attempting the undo, once cracked off, cup of tea, allow it all to cool before carrying on. That would be my advise.
Andy
Post #257611 9th Aug 2013 7:40pm
ttuck3r
You need to bombard it with penetrating oil and before you attempt it hit it with heat off a blow torch its more localised, i only tried this after on the turbo flange bolts and it worked a treat..
Post #257614 9th Aug 2013 7:46pm
ttuck3r
Well i collected my Landy from Strathearn Engineering today all fixed up, very happy Thanks to the Lads for getting to it so quickly.. Thumbs Up
Post #258464 13th Aug 2013 8:21pm
ttuck3r
Out with the old EGR
In with the Blanking kit
Post #259210 16th Aug 2013 8:13pm
Will.I.AM
United Kingdom 2005 Defender 130 Td5 HCPU Kaikoura Stone
Try using loctite freeze spray, this temporarly shrinks the bolt. It helps.
Post #259283 17th Aug 2013 12:37am
ttuck3r
Gave the engine a good clean up today after all the shenanigans with the EGR
Post #260666 22nd Aug 2013 7:59pm
superspoons
England 1998 Defender 90 V8 Petrol 50th Auto Atlantis Blue
That's come up a treat Thumbs Up What did you use ? Any products or lots of elbow grease ?? Cheers,
Superspoons
Post #260672 22nd Aug 2013 8:13pm
ttuck3r
no elbow grease at all, simply spray on G101 wait 10min and blast off with a semi powerful garden hose!
Post #260683 22nd Aug 2013 8:39pm
