Home > Td5 > EGR blank kit FAIL |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5779 |
Sorry to hear that, feel for you.....
Time for a drink Andy |
8th Aug 2013 8:10pm |
ttuck3r Member Since: 03 Feb 2013 Location: Dunning Scotland Posts: 277 |
Unnecessary quote removed
Thanks Dude, Whiskey on the rocks number 3 on route.. |
8th Aug 2013 8:12pm |
johnnyd Member Since: 13 Apr 2013 Location: Chippenham Posts: 1006 |
Same happened to me when I tried to fit mine......but I could still drive it, cost me 200 quid
JD 2008 TDCi 2.4 XS CSW |
8th Aug 2013 8:25pm |
O man i can feel my wallet starting to sweat.. |
8th Aug 2013 8:36pm |
I don't think those two Allen bolts would ever come loose on a Defender over one month old
8th Aug 2013 8:40pm |
kipperthedog Member Since: 27 Jun 2013 Location: Down South Posts: 403 |
....I am really looking forward to fitting mine now.......
Someone who has fitted a few to Discovery 2s did advise me to spray with penetrating oil for a week or so (!) and then do the job carefully when the engine is warm and the manifold is therefore hot. .......can't afford a disaster just now though! |
9th Aug 2013 5:50pm |
Get the engine HOT, then tighten them slightly before attempting the undo, once cracked off, cup of tea, allow it all to cool before carrying on. That would be my advise.
Andy |
9th Aug 2013 7:40pm |
You need to bombard it with penetrating oil and before you attempt it hit it with heat off a blow torch its more localised, i only tried this after on the turbo flange bolts and it worked a treat.. |
9th Aug 2013 7:46pm |
Well i collected my Landy from Strathearn Engineering today all fixed up, very happy Thanks to the Lads for getting to it so quickly..
13th Aug 2013 8:21pm |
Out with the old EGR
Click image to enlarge In with the Blanking kit Click image to enlarge |
16th Aug 2013 8:13pm |
Will.I.AM Member Since: 16 May 2013 Location: Hertfordshire Posts: 418 |
Try using loctite freeze spray, this temporarly shrinks the bolt. It helps.
17th Aug 2013 12:37am |
Gave the engine a good clean up today after all the shenanigans with the EGR
Click image to enlarge Click image to enlarge Click image to enlarge |
22nd Aug 2013 7:59pm |
superspoons Member Since: 16 Apr 2012 Location: Herts Posts: 314 |
That's come up a treat What did you use ? Any products or lots of elbow grease ?? Cheers,
Superspoons |
22nd Aug 2013 8:13pm |
no elbow grease at all, simply spray on G101 wait 10min and blast off with a semi powerful garden hose!
22nd Aug 2013 8:39pm |
