![]() | Home > Td5 > EGR blank kit FAIL |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5800 ![]() ![]() |
Sorry to hear that, feel for you.....
Time for a drink ![]() Andy |
ttuck3r Member Since: 03 Feb 2013 Location: Dunning Scotland Posts: 277 ![]() ![]() ![]() |
Unnecessary quote removed
Thanks Dude, Whiskey on the rocks number 3 on route.. |
johnnyd Member Since: 13 Apr 2013 Location: Chippenham Posts: 1006 ![]() ![]() ![]() |
Same happened to me when I tried to fit mine......but I could still drive it, cost me 200 quid
![]() JD 2008 TDCi 2.4 XS CSW |
O man i can feel my wallet starting to sweat.. ![]() |
I don't think those two Allen bolts would ever come loose on a Defender over one month old
kipperthedog Member Since: 27 Jun 2013 Location: Down South Posts: 403 ![]() ![]() |
....I am really looking forward to fitting mine now.......
Someone who has fitted a few to Discovery 2s did advise me to spray with penetrating oil for a week or so (!) and then do the job carefully when the engine is warm and the manifold is therefore hot. .......can't afford a disaster just now though! |
Get the engine HOT, then tighten them slightly before attempting the undo, once cracked off, cup of tea, allow it all to cool before carrying on. That would be my advise.
Andy |
You need to bombard it with penetrating oil and before you attempt it hit it with heat off a blow torch its more localised, i only tried this after on the turbo flange bolts and it worked a treat.. |
Well i collected my Landy from Strathearn Engineering today all fixed up, very happy Thanks to the Lads for getting to it so quickly..
Out with the old EGR
![]() Click image to enlarge In with the Blanking kit ![]() Click image to enlarge |
Will.I.AM Member Since: 16 May 2013 Location: Hertfordshire Posts: 419 ![]() ![]() ![]() |
Try using loctite freeze spray, this temporarly shrinks the bolt. It helps.
Gave the engine a good clean up today after all the shenanigans with the EGR
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
superspoons Member Since: 16 Apr 2012 Location: Herts Posts: 314 ![]() ![]() ![]() |
That's come up a treat
![]() Superspoons |
no elbow grease at all, simply spray on G101 wait 10min and blast off with a semi powerful garden hose!
