- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
Cheshire110
smb wrote:Without doubt the best Mod and one that cost nothing but 15 mins of getting dirty was taking out the steering stops. Completely transforms the low speed drivability.
Now at least, I don't have to do 10-Point turns to park it
Is there a thread on how to do this somewhere? I'm new to steering etc... Cheers, David
7th Aug 2013 2:17pm |
HTB
davidwhittaker wrote:smb wrote:Without doubt the best Mod and one that cost nothing but 15 mins of getting dirty was taking out the steering stops. Completely transforms the low speed drivability.
http://defender2.net/forum/topic15312.html...ring+stops
7th Aug 2013 7:51pm |
smb
Supacat wrote:Sounds a simple mod - I'd just want to check the limits of the steering & power pump first to ensure you don't introduce a new issue.
This mod is dependent upon the size of tyre you've got on and the offset of the wheel. If you can and have the facilities take the suspension on the front to the extreme points(highest/lowest) and the steering to the extreme(left/right) when at the highest/lowest to guage how much you can adjust your steering stops. If you can't do this then just bear in mind that what is ok for normal everyday road driving will not necessarily be ok for off-road.
If you get it right it will transform parking and positioning.
9th Aug 2013 9:29am |
