Home > Maintenance & Modifications > Favourite under £250 mods |
Cheshire110 Member Since: 26 Jul 2013 Location: Cheshire/London Posts: 2767 |
Is there a thread on how to do this somewhere? I'm new to steering etc... Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
7th Aug 2013 2:17pm |
HTB Member Since: 24 Mar 2013 Location: Surrey Posts: 71 |
http://defender2.net/forum/topic15312.html...ring+stops |
7th Aug 2013 7:51pm |
smb Member Since: 15 Jan 2013 Location: Cheshire Posts: 1232 |
This mod is dependent upon the size of tyre you've got on and the offset of the wheel. If you can and have the facilities take the suspension on the front to the extreme points(highest/lowest) and the steering to the extreme(left/right) when at the highest/lowest to guage how much you can adjust your steering stops. If you can't do this then just bear in mind that what is ok for normal everyday road driving will not necessarily be ok for off-road. If you get it right it will transform parking and positioning. |
9th Aug 2013 9:29am |
