Home > Wheels & Tyres > tracking - wheels
Page 5 of 5 <12345
Happyoldgit
Just keep well away from Suffolk / Norfolk please Whistle
Mr. Green Steve.
http://forums.lr4x4.com
Post #256874 6th Aug 2013 10:09pm
I am beginning to think that maybe, just maybe, the problem is ...
...you're jinxed!
Post #256888 6th Aug 2013 10:45pm
Caterham
still not got round to swapping the tyres over but I've noticed the f/os tyre is wearing more on the inside.
garage had a quick go at adjusting the tracking last night and the one side of the track rod is seized Crying or Very sad
however I'm a little perplexed as he said the old fashioned design is such that when you adjust the track it adjusts both sides???
only my front os appears to be out so hows that if the tracking adjustment adjusts both equally?
Post #271100 3rd Oct 2013 8:25am
tatra805
Slovakia 2008 Defender 110 Puma 2.4 CSW Bonatti Grey
catherham,
to adjust 1 side you need to disconnect the ball joint of that side and turn it in/out. once ball joints are connected turning the arm will adjust both sides equally and simultaneous.
Also, when replacing the ball joints both need to be screwed in till a set length which you find in the workshop manual. both wheels are then set at same angle (toe-in / toe out) to the axle. After that you regulate the toe-in by turning the rod when setting the geometry.
This is only tracking adjustment, setting center steering box to straight ahead position is done by adjusting the link between steering box and wheel, and then center position of steering box and center position of steering wheel by jumping teeths on the steering wheel boss.
Hope this helps?
Smile
Post #271116 3rd Oct 2013 10:03am
Caterham
tatra85
many thanks for this. I suspect I need to crawl under the car while reading your note.
is it possible that your note should read:
to adjust 1 side you need to disconnect the ball joint of that side and turn it in/out. once ball joints are connected turning the ROD will adjust both sides equally and simultaneous
and not
to adjust 1 side you need to disconnect the ball joint of that side and turn it in/out. once ball joints are connected turning the ARM will adjust both sides equally and simultaneous
many thanks
Post #271118 3rd Oct 2013 10:21am
tatra805
Crying or Very sad you catch me on my weakness Laughing
never remember the exact terms of those rods
So correcting my txt:
to adjust 1 side you need to disconnect the tie rod ball joint of that side and turn it in/out. once ball joints are connected turning the tie rod will adjust both sides equally and simultaneous.
Also, when replacing the ball joints both need to be screwed in till a set length which you find in the workshop manual. both wheels are then set at same angle (toe-in / toe out) to the axle. After that you regulate the toe-in by turning the tie rod when setting the geometry.
adjusting the straight ahead position is done by centering the steering box and adjusting the drag link till wheels are centered.
Thumbs Up
edit: got the picture from here: http://www.offroaders.com/tech/Steering-Systems.htm
Post #271121 3rd Oct 2013 10:34am
Page 5 of 5 <12345
