Home > Puma (Tdci) > 52 - 53 mph in 6th
Page 1 of 4 1234>
Caterham
52 - 53 mph in 6th
anybody get or had a vibration at this speed (52mph / 1750 rpm)?
under no load no problem but with light acceleration the vibration suddenly arrives - a bit like pins and needles.
nothing major but frustrating after a while.
(Mal - clearly I'm not referring to mine cos mine is now perfect) Whistle
Post #254988 31st Jul 2013 5:17pm
BigWheels
What are your tyre pressures front & back? Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
Post #254990 31st Jul 2013 5:18pm
Caterham
I don't know but going by the ride, visual and general noise I'd have thought they were about right.
have you experienced vibration at a particular speed with either under or over pressure?
this is defo related to transmission or or exhaust. the engine sounds sweet but you can bring the vibration on with slight movements of throttle. no throttle and it goes. keeping speed constant and there's a slight vibration which increases slightly under gentle acceleration so in this case I'm 99% sure its not related to the tyres. that said it does feel similar to the vibration you can get on a slightly rough tarmac road surface.
Post #254994 31st Jul 2013 5:24pm
mk1collector
It's a defender! They vibrate! Thumbs Up
Post #255000 31st Jul 2013 6:04pm
Caterham
hmm.
may be your right but Confused
please excuse my sceptisism cos having been told they all do that more than once and then to have things fail I'm not convinced.
I'm actually thinking these defenders aren't nearly and rough and ready as some would have you beleive ??
Post #255009 31st Jul 2013 6:14pm
adafish
United Kingdom 1984 Defender 110 300 Tdi DCPU Stornoway Grey
have you tried going FASTER ? Putting Dreams on Drives at JLR Solihull..
Post #255012 31st Jul 2013 6:28pm
Dave-H
Dont discount wheel balance without having them checked ... 50 - 55 mph is the textbook speed for a out of balance tyre vibration. Guns and Landrovers .... anything else is irrelevant.
Post #255019 31st Jul 2013 6:37pm
Norm4n
Yes I have, drop to 5th and it pulls a treat though
Post #255021 31st Jul 2013 6:51pm
Lou Sparts
Out of shape handbrake drum Whistle 2005 Td5 90 XS
Steve
Post #255023 31st Jul 2013 6:54pm
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
Check for lost wheel balance weights on both the outer and inner rims of the wheels? Swop wheels around! Sounds very much like wheel balance vibration which would disappear if you went a little faster eg: 60mph. Whistle LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #255026 31st Jul 2013 6:56pm
Caterham
tried going faster but the fuel ecomomy drops....
Laughing
its gone by about 60 to be fair.
DaveH - don't think its wheels cos its increases with engine load.
ie the same speed with varyiing engine load varys the amount of vibration - I wouldn't have expected that to impact on the wheels.
I think I need to start with looking at heat shield and prop / drum (not sure this could make any difference but I still have my suspicions about the egr (not because of the vibration but always doubted it - but I've always been before) - has anyone ever know the egr to cause a vibration at that sort of rpm ?
thanks for the feedback.
its nothing major but I'm sure its not right so would like to resolve before the warranty is up. the way I see it is it'll only get worse. I'd rather it get worse and LR pick up the bill than me.
Post #255028 31st Jul 2013 7:03pm
Natlas
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Aintree Green
Hi Caterham, I have noticed you have not had much luck with your landy, thinking of things that can cause vibration, the obvious ones are prop shaft or their UJ's, wheels out of balance as already mentioned. Have you had any new brake discs lately? (or any new item on a driveshaft?) I once bought some supposedly top of the range aftermarket discs and pads and three months later after lots of wheel balancing etc eventually found out one of the discs had a faulty casting, which by the time I took it off was clearly visible as a fault line.
Probably way off the mark but just thought I'd mention it.
Good luck, John. 2.2 90 XS
88" Series One
Old Norton Smile
Minerva
Post #255031 31st Jul 2013 7:09pm
Caterham
thanks John.
nothing in the brake department has been replaced.
transmision wise extention shaft input shaft thing was replaced and the gearbox, but I'm confident these are now ok
propshaft... hmmm. i did try and replace a grease nipple (was supplied the wrong one) that seems never to have been there or has decided to disappear (well I guess it is the holiday season after all). there didn't appear to be any excessive play in the uj's but then I'm no expert.
perhaps this could be the problem. presumably if theres excessive play this would show up and an out of balance vibration because of it isolating ?
Post #255035 31st Jul 2013 7:22pm
jst
Ujs will normally knock, i doubt its them causing the issue. are they hot after a drive?
wheel balancing gets my vote. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #255068 31st Jul 2013 8:34pm
Caterham
wheel weights all in place (or at least they appear to be).
just noticed something that I've not done before but will be from now on in. when turning the engine off leaving the clutch depressed. engine stops and everything sounds and feels 'proper' nice.
this leads me to wonder could there be an issue with the clutch and hence the vibration above ? (just a thought)
- hight recommend you all try the clutch in when turning off - sweet. Thumbs Up
Post #255076 31st Jul 2013 8:50pm
Page 1 of 4 1234>
